Badger5Chris Nott
Results 1 to 7 of 7
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    painting interior trim?
    hi folks
    after years of searching for double din centre console conversion parts ive come across some at a reasonable price
    only trouble is its in light grey and my interior is dark grey
    has any one had good results in painting this type of plastic, if so what did you use?
    cheers kev
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    I would use a plastic based primer to achieve durability.
    Like any painting process, its all in the prep mate;
    Firstly, thoroughly clean the part
    Then score/sand it to key the base
    Clean again
    Then apply primer, 2 or more coats dependant on finish(shine, matte etc) leaving 15-20 drying periods between
    Leave part to fully cure/dry, overnight, then wet sand
    Clean again
    Then start applying top coats, leave again to cure overnight
    Wet sand to a smooth finish
    Then apply laquer coats, wet sand if needed.
    Project RS28 build
    A4 b6 TDI V6 Quattro Sport
    Nov 2010
    West london
    150
    You can buy a sort of bumper textured finish paint from any good paint supplier you will have to get some red scotch brite to key the surface then find the paint colour you like also as foxmeister said get a plastic primer the one I use is clear and is more an adhesion promotor paint this on leave for 5 10 mins an then spray straight on to it with the textured finish paint or just an aerosol ( if you go for just a paint get some primer to give the top coat some depth and follow as above reply ) hope all goes to plan mate
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    cheers guys,
    came across this and it seems that plastic can be dyed?
    www.vinyldye.co.uk
    think ill give it a go with some matt black and see how it turns out
    thats if i buy the console, going to look at it tommorrow
    kev
    90 eunos roadster
    Rick_RS4's Avatar
    Dec 2010
    25
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    i've used the halfords stuff on a dashboard in a nova before (kinda soft touch vinyl surface) and it worked well
    rasa4 has painted his glovebox iirc
    TD5 Land Rover Defender build
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Halfords gear is actually good quality, paint wise anyway!
    Used it for painting my wheels, and primers etc, aluminuim paint for mirrors also, good quality stuff!!!
    Project RS28 build
