AH FabricationsBadger5
Results 1 to 16 of 16
    Jan 2011
    County Durham
    22
    Quick question - how do you remove the centre "wooden" panel?
    The radio in my PFL A4 has packed up. Only the rear speakers were working yesterday, and this morning there's no power to the unit at all...
    I suspect that the wires have worked loose on the back (the previous owner replaced the HU and I reckon he's not fitted it properly)
    I've got keys to remove the HU, but can't get them to lock properly. The local Audi garage tried and also couldn't get it to come out, saying that the right hand pin had bent too far and the key couldn't engage with it properly. They suggested taking the wooden panel off the front and trying to slide a screwdriver down the side to bend the pin back in. Failing that they suggested taking the covers under the steering column off and coming at it from behind...
    So, first things first, how do i take the wooden centre console panel off? I don;t want to force it and snap it!
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,528
    im sure that they just pull off
    and be careful if goin in from behind i hear it can be nasty
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    Yes it just clips off but the clips have a tendency to break I had same problem with mine right hand pin was bent over to much I had to get a small pick with a slight angle to pick it over but it slightly damaged the radio was a ***** to get at but with some patience you will get it out eventually !!
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    Its a metal plate. can't you see you snapping that.
    With out wanting to insult you, you are putting the keys in and pulling outwards as you pull towards you?
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,388
    I'm pretty sure the PFL panel is held on with some bolts, which are only accessible when the stereo is out.
    You can try removing the glovebox and trying to push the head unit out from behind.
    That said, the wood is bloody awful, and the concert is a pile of crap too so get in there with the biggest screwdriver you can find, burst it all out and replace with a decent HU and a nice black surround :D
    TD5 Land Rover Defender build
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    BRB i'm going to take my unit out and take a look.
    Aragorn got my thinking.
    1min.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    There are two bolts behind the head unit that holds the face plate on.
    "Stick a V8 in it!"
    15,388
    Jan 2011
    County Durham
    22
    balls, so pulling it off (so to speak) is out of the question then!
    Jan 2011
    County Durham
    22
    will try a long screwdriver down the side of the unit from the front then... before hacking the panel out all together!
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    that wont work.
    cause the clips are behind the faceplate and the faceplate is wider that the unit it self.
    Jan 2011
    County Durham
    22
    Ok... So what then?
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    Quote Originally Posted by durham-dazzler View Post
    Ok... So what then?
    keys, wiggle and pull.
    I'm out of ideas. lol
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,093
    Remove the drivers side under dash. and go at it from the back. Watch the metalwork though as I found the hard way it can be sharp and still have the scar to prove it
    Life begins at 140mph
    www.passionford.com
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    It is very sharp behind there and the clips are kinda stuck behind metal work . Try some merc keys push the radio in aim the keys to the outsides of the unit and it should come out . Yes the wooden panel has two 8mm bolts holding it behind the outer edges of the unit . Failing that you can actually pull the front panel off the the unit just watch out for the spring on the cassette flap if it has one put a bit of heat on it first so it bends the clips rather that snapping them . Failing that take it to a good audio shop and get them to remove it for you . good luck and be patient .
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    Jan 2011
    County Durham
    22
    Radio out!
    Took the drivers side dash cover off, chisel on the side of the radio pulling the frame away from the unit and pulling the radio out at the same time... bent the side of the radio slightly but it came out!!
    However, the radio still doesn't work!
    Checked the leads, the fuse on the unit and all the fuses in the box but nothing... just will not turn on!
    I'm now thinking that the unit is goosed
    Still, at least now it's out it's easy to replace it!
