EM TuningVolks Autos
Results 1 to 19 of 19
    Sep 2009
    Gloucestershire
    54
    Stupid sump plug question
    Ok, so I'm trying to do an oil change on the car. Got to getting the sump plug off, and it seriously won't budge. Now I'm pretty sure I'm right, but it's the same as any other bolt - anticlockwise to undo. It's definitely not the other way for some obscure reason?
    On this engine it's on the right hand side of the sump, facing out towards the passenger side wheel. I'm sure it's just seized, but thought I'd ask in case there was a chance it was different and all I've been doing is tightening it.... Sounds a daft question, but you never know...
    /sprint_48 / Audi b5 A4 1.8T //// // //
    Badly Parked Dubs
    PaulTheo's Avatar
    Aug 2010
    Bristol UK
    126
    Yes normal thread but can be tight. Use a good socket and bar keep it straight and don,t round it off.
    Sep 2009
    Gloucestershire
    54
    Cheers, knew I was right but best to cover all possibilities. Maybe it's just my socket isn't man enough for it. Will have a hunt around for something else to try. Have tried 3 blasts of WD40 so far. Got to hate over tightened bolts....
    Badly Parked Dubs
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,301
    I normally just use my 1/2" drive "wall drive" socket and breaker bar.
    What are you trying to undo it with?
    TD5 Land Rover Defender build
    Sep 2009
    Gloucestershire
    54
    Just a normal 17mm socket. It's not a great kit I don't think, bit of play in it and the bolt is ever so slightly rounded which isn't helping (last change was done by a garage ). It's still solid on there. The only thing like a bar I have to hand is a standard wheel bolt removal tool, which I've slid over the socket handle to give me more leverage, but still no joy. Losing my rag now!
    Badly Parked Dubs
    tux
    tux's Avatar
    May 2010
    Notts/Derbys Border
    89
    I find its easier to get a good straight grip on it with a good old fashioned spanner. If its really, really stuck you could try warming the sump pan a little as a last resort with a heat gun/blowtorch. Don't go mad though.
    And on a parallel note, if you have changed your sump pan for a new one, don't assume the factory fitted sump bung is tight. Ask me how I know!
    If it can't be fixed with a hammer, then it must be an electrical problem
    Sep 2009
    Gloucestershire
    54
    Have admitted defeat after 2 hours of swearing, sweating and WD40. Am going to change tactics and use a syphon pump instead before it costs me a new sump!
    Badly Parked Dubs
    mattpanton's Avatar
    Sep 2005
    Suffolk, UK
    123
    Did you try shocking it? decent fitting spanner and a few sharp taps from a mallet on the end of the spanner
    2001 A4 Avant SE 1.9TDi
    TDIPOWARRR
    Jul 2010
    618
    When you do get it off, one of these might be usefull for you:
    Browser Warning
    Sep 2009
    Gloucestershire
    54
    Quote Originally Posted by mattpanton View Post
    Yeah, had the hammer and wooden mallet to it. Think a slightly rounded bolt and average socket set making things a ball ache. Will try the pump method and see what happens
    Badly Parked Dubs
    "Stick a V8 in it!"
    15,301
    TBH, your better fixing this properly now, than messing around trying to syphon oil out etc.
    Perhaps someone off the forum is nearby that can lend a hand?
    Nov 2010
    Derby
    WD40 isn't a penetrating oil- WD stands for 'water displacement'...
    Get some 'plus gas' on it, leave overnight and try again with the above suggested methods..
    Jun 2010
    196
    half inch ratchet with a 6 sided socket(importent as a multi sided one will just totaly destoy your aready rounding bolt)keep straight and a long tough bar i use a cut up scaff tube but can use breaker bar = jb done id of lent a hand but im nowhere near mate jobs always become a nighmare when you hae to makedo with a tool that just wont hack it bestto just stop acuire wat you need and go again
    Sep 2009
    Gloucestershire
    54
    WD may not be the best, but it does say 'loosens rusted parts' on the can.
    Cheers for the offer mate. Need some better tools I think....
    Badly Parked Dubs
    flat out
    north weald essex
    220
    Quote Originally Posted by sprint_48 View Post
    to be fair though the sump plug isn't rusted, it's a chemical reaction if it won't budge or a mechanical one if it hasn't fused.
    penetrating oil will be best.
    or maybe let a shop monkey do it? then its their fault and responsibility to fix if it goes horribly wrong ?
    2001 1.8T B5 Black A4 Avant Votex kit and Ecru Leather
    Sep 2009
    Gloucestershire
    54
    The offending bolt:
    Badly Parked Dubs
    "Stick a V8 in it!"
    15,301
    Heh that looks properly mashed.
    I'd be getting yourself a new plug first off, then let a garage get it out and refit your new plug.
    Mar 2010
    MARGATE, KENT
    35
    I took mine to garage and they tried (allegedly) all kinds of bars and couldn't budge it. I bought a ring spanner and mallet from halfords, gave the plug a few whacks with the mallet and a small amount of wd. put the spanner on it and then put my foot on the spanner (oh yeah had the bonnet up too) I held on the bumper and pushed like f**k with my legs until I felt it move. I thought it had just burred the head of the plug but had actually moved it, enough to give it another turn on the spanner. also they do tighten up easily and refuse to budge without force.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,965
    +1
    or keep trying it your self.
    I'd try a smaller socket or a pair of good mole grips and use your leg, Like nate did.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
