Badger5Monster Motorsport
Results 1 to 7 of 7
    gaz71's Avatar
    1.8T Quattro Sport AJL
    Jul 2009
    Torbay
    287
    Question Cd changer removal
    Hi,
    Been having issues with my stereo throwing up random error codes when playing CD's.
    I want to remove the CD changer so that I can check it out mechanically and give it and the optical head a good clean.
    Had a look but cannot figure out how it comes out of the metal bracket that it is mounted in.
    It's located in the boot.
    Can anyone give me any pointers as to how to remove the changer?
    To date - 2.5" Jetex exhaust, Generic re-map, Silicone hoses, N75k, shiny 17's, FK Springs
    Wanted - Sports cat, bigger downpipe, FMIC, Bigger turbo
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,324
    On mine, the entire bracket slid out after removing 2 or three screws, then you can unbolt the changer from the bracket.
    Not sure if its the same on a saloon.
    TD5 Land Rover Defender build
    TDi Powerrrr
    Aug 2010
    North Devon
    404
    Remove the n/s boot trim,then undo 2 or 3 8mm bolts and the whole bracket comes out,after undoing the wiring plug.
    hth
    tony
    gaz71's Avatar
    Jul 2009
    Torbay
    287
    Thanks guys.
    Got it out, now to perform surgery
    gaz71's Avatar
    Jul 2009
    Torbay
    287
    Will an aftermarket cd changer fit onto existing wiring connection?
    Any recommendations?
    "Stick a V8 in it!"
    15,324
    Mine had a panasonic unit fitted along with some really tatty wiring adaptor.
    It didnt work though, so i skipped it.
    TDi Powerrrr
    Aug 2010
    North Devon
    404
    I got a factory changer spare from my avant,in full working order if you're after one.I will check and see if it will fit a saloon.
    tony
Tags for this Thread
