EM TuningJMB Retrofits
Results 1 to 9 of 9
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,030
    A clip & rear window trim
    First is the clip.
    You've all seen them before and I wanted one.
    So I bought one and fitted it.
    Heres some pictures.
    Remove the A pillar trim and your left with this.
    Fit clip in the location you like. I used double sided sticky tape. I was going to use a screw but due to the angle and how close it is to the screen, I went with the tape.
    and then fit it all back together. Time will tell how long the tape holds. It should last cause the pillar also holds the clip.
    Next was the little metal panel on the rear windows.
    When I replaced my manual rear windows for electric rear windows I forgot to swap this bit over.
    With a spare 5mins I finally got round to it.
    The corroded panel, which is also the wrong colour.
    Remove the inside plastic panel to expose the torx bolt.
    Slide the panel down as far as it can go and then wiggle it till it comes out.
    And refit the correct panel and put it all back together.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    498
    Can you resize the images, too big for my screen!
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,030
    Quote Originally Posted by Sulli79 View Post
    Done.
    Jul 2011
    do you know where to get the side panels from, your motor is the same as mine and I am starting to have lots of little issues with it that need fixing.
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,030
    Quote Originally Posted by netdef View Post
    breakers yard or Audi.
    I got the panels that I removed due to the paint flaking off.
    Bit of work and some paint and they will look new again.
    dest's Avatar
    Jul 2007
    Northants
    195
    What is the clip for?
    Avus B5 RS4
    Gutted downpipes, non-res Milltek, custom MRC remap, H&R ARB's, B7 RS4 brakes, oil cooler, Tanoga short shift
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    +1 with dest, is it for when you get speeding tickets
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,030
    Quote Originally Posted by dest View Post
    The clip is to hold parking tickets, the pay and display sort.
    I hate sticking them to the window and if you put them on the dash there is a chance of them blowing away when shutting the door.
    This way they stay nice and secure on the window.
    Quote Originally Posted by Bradderz_1988 View Post
    I drive a diesel auto, no chance of speeding cause I'm to relaxed and the car is to slow.
    dest's Avatar
    Jul 2007
    Northants
    195
    Fair enough
    I just check mine after Ive shut the door!
    Handy to know about the rear trim though as I toying with getting mine carbon wrapped
    Avus B5 RS4
