AH FabricationsVolks Autos
Results 1 to 17 of 17
Thread: which h7 bulbs?
    205man's Avatar
    May 2006
    worcestershire, uk
    1,014
    which h7 bulbs?
    with the bad weather here im looking to put some brighter, more white looking bulbs in my headlights
    ive h7 in both dip and main beam fitted as standard,
    i dont want to really go down the hid route , mainly due to cost at the moment, so looking for some upgrade suggestions , also want to replace the sidelight bulbs as they are very yellow looking
    should of thought of this in the summer lol
    thanks
    alan
    icenutter's Avatar
    Jun 2006
    595
    phoenixv6quattro's Avatar
    staylowmovefast
    Sep 2009
    wycombe
    1,391
    Hello mate. I,ve just fitted some LED sidelights and number plate lights to mine. Looks pretty good WITHOUT looking even the slightest bit chavvy (there white LED's of course!lol). You can get these for about a 8 quid at most auto stores. Dipped beam wise, dropped in some Osram nightbreakers a while back and it makes a difference, but thought I could do better so bought some Phillips high performance bulbs (dipped beam only, hardly ever use my full beams so thought I'de save some money!) which made a hell of a difference. 30 quid for 2, but well worth it! You can get these from ECP.
    !!BINGO BONGO!!
    May 2010
    274
    Osram Night Breaker PLUS H7 from Power Bulbs | Free Worldwide Delivery
    NEW Philips X-treme Vision H7 from Power Bulbs | Free Worldwide Delivery
    I've got the older Philips model ( Philips X-Treme Power H7 from Power Bulbs | Free Worldwide Delivery ) and they're good. I really want to try the two I've mentioned above but I can't justify buying them when they're not needed! Though I'm trying to get my dad to take em off me
    8P Audi A3 2.0TDI Quattro Sport - what a change from my 1.0L CorsaC!!!
    follow me on Twitter - Jonay1990 for #Photography #Aviation #Mil #Automotive #Subsea
    Apr 2009
    west London
    35
    Quote Originally Posted by phoenixv6quattro View Post
    Hi there-did you have to use resistors across the sidelight feed to get them to work?
    mine are the H6W LED style sidelights for facelifted version and no luck so far...
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,914
    No, they should jsut work.
    Resistors are only for cars that monitor the bulbs, and the B5 doesnt monitor front sidelights.
    LEDs are polarised though, so try fitting the bulb the other way round.
    TD5 Land Rover Defender build
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,656
    I fitted the H4 version to mine and my mate fitted the H7s.
    They are very good.
    highly recommended.
    A4 B5 Double Din, RNS-d, TMC, Full Sports Leather Heated with Leather Door Cards and Lower Door trims all for sale.
    Audrey's Build Thread
    RIP Audrey. She's being broken down.
    New Car, New Thread.
    Scott's Akoya Silver A8
    Apr 2009
    west London
    35
    You can't fit them the H6W style LED's the other way round i'm afraid as the pins are offset to stop this.
    I originally bought some 501 type bulbs but they dont fit my headlamps.
    It's interesting that you say the B5 doesn't monitor sidelight bulbs as mine now say there is bulb out and i assumed it was my sidelight bulb as it has blown.
    I need to go and check all the bulbs in that case...
    "Stick a V8 in it!"
    14,914
    B5 monitors Dip beam headlights, rear side (tail) lights, brake lights.
    "Stick a V8 in it!"
    14,914
    Perhaps its a blown fuse?
    Apr 2009
    west London
    35
    Yes just checked and the rear tail is out which went coincidentally when i plugged in the new LED side light...they are same side(drivers)
    Is there a common fuse for sidelight and rear tail?
    Apr 2009
    west London
    35
    Quote Originally Posted by s4best4 View Post
    Ahh yes looks like its fuse 22 as just checked manual...
    Looks like ive been running around for a week with a duff taillight so, thanks for the pointer!
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    This may be off topic but i remember some led H6W fitting to a 5 series turned out the polarity was the other way round and also on the map lights in the B5 . so if both aint working try the originals back in see if they still work
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    staylowmovefast
    Sep 2009
    wycombe
    1,391
    Hello mate yes they were plug and play, no resistors needed. I have tried the Osram Nightbreaker Plus and honestly the Phillips variants are better. The ONB's are good, but not so as the X-tremes.....
    !!BINGO BONGO!!
    aidank1981's Avatar
    Nov 2006
    Shetland Islands
    251
    Are we taking Phillips extreme vision or Phillips extreme power as both variants are offered? Vision states 100% light, power claims 80% more? Maybe there both better than ONB's?
    Audi S4 Black on Black. 1999(T)facelift, Aluminium Mirrors, KW Varient 3 coilovers, AmD remap, uprated D/V's, 315bhp375Lb/ft torque, milltek down, 100cpsi cats an back, S4 B6 18" Oem runnin toyo T1-R's. Rs4 B5 front brakes still to fit...
    staylowmovefast
    Sep 2009
    wycombe
    1,391
    We're talking about the X-Treme vision NOT power. Performance aside theres like a 20 quid price difference! A lot of money for two bulbs but IMO well worth it. The best you can do shy of Xenons/HID conversion (which is a major ball-ache due to all the extra stuff you need for them to be legal!).
    !!BINGO BONGO!!
    Apr 2009
    west London
    35
    Quote Originally Posted by andybnwc View Post
    Hi Andy-No it was a fuse gone caused by my LED replacements and my schoolboy error of trying to change it while still switched on...I have some fleabay LEDS in now so we'll see how good they are.
    I'm grateful for all the useful help as this isn't a good time of year to be driving around with a duff stop/tail light-if you know what i mean...
