Volks AutosMonster Motorsport
Results 1 to 15 of 15
Thread: I hate snow....
    Jan 2007
    42
    I hate snow....
    So, it takes me just over 3 hours to drive 20 miles home from work. get within spitting distance of the house and the car dies!
    not what you want before Xmas.
    i was sitting at traffic lights when the revs dropped like it was going to stall then revs came back to normal but the dash lights seem a little darker and the battery light comes on, pull away and notice that the power steering isnt working properly. car is still driving fine no lose of power. get a bit further along the road to where i can pull over and get out of the way of the other cars and i notice that the temp gauge is right up to 120! then i get the beep and the thermometer sign flashes up.
    so turn off the engine and pop the bonnet. engine isnt that warm and ive got no steam like i would expect if it had over heated.
    i reckon the AA are going to be fairly busy tonight and as im sooo close to home ive left it where it is till the morning.
    any ideas what this could be? is it just because of the stop start journey home in the cold?
    cars is a 1996 T Sport.
    Thanks in advance
    Simon
    S3 Paul's Avatar
    Oct 2006
    2,759
    What engine is it exactly?
    Noggy Blue 2001 S3
    Jan 2007
    42
    1800 turbo. think its an AEB
    S3 Paul's Avatar
    Oct 2006
    2,759
    Is the alternator drive belt still there?
    this would effect the power stearing and the lights dimming,
    Noggy Blue 2001 S3
    Jan 2007
    42
    no torch in the car an was too dark to see anything.
    going to go back to it in the morning so will look then. is hte alternator belt easy to see?
    Iam pretty useless when it comes to cars LOL
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    Sounds like the belt to me. If there is a few pulleys at the front of the engine with no belt round them that will be it. Cant remember how easy it is to do,i did mine when i had the front off anyway.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,904
    Yep, will be the Belt, probably caused by a faulty tensioner.
    It drives the alternator, PAS and water pump, so the symptoms all ring true.
    The tensioners go squint, and rip the belt up.
    TD5 Land Rover Defender build
    Jan 2007
    42
    cool thanks guys
    pjw
    Nov 2010
    Helensburgh
    203
    Pretty easy fix if its any consolation.
    Paul
    Purpur A4 B5 - -50mm - S4 Interior - RS6 Alloys - 3" Stainless Exhaust - K&N Intake - HID
    Feb 2009
    228
    Cant remember my old aeb setup but I had a similar problem on my tdi. Turns out it was the alternator pulley, it moved forward on the shaft causing the belt to jump off. Hopefully your problem isn't tha.
    Jan 2007
    42
    just been to look at it, aux belt has snapped. just how easy is it to replace?
    luckily for me its broken down a few hundred yards from a friends house so i could possibly limp it to his place.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,355
    The hardest bit from memory is dropping the waterpump pulley to get the drive belt off to get the aux one in behind it.
    15mm spanner to twist the tensioner back, i think that's it.
    "Stick a V8 in it!"
    14,904
    As i said above, get another tensioner for it too, usually its that that causes the problem!
    Jan 2007
    42
    i need to get the timing belt done in 7000 miles so im halftempted to be lazy and pay someone to do both at the same time. not doing anything in this bloody snow though!
    Aug 2010
    1,540
    yeah id get the recovery to take it to your garage then if the timing belts due soon.
