Monster MotorsportVolks Autos
Page 1 of 2 12 LastLast
Results 1 to 40 of 43
    Dec 2010
    Inverness
    38
    My A4 TDI issues
    Hello All
    Audi 1.9 TDI 90
    Here are the few issues I have with my audi
    Problem 1 - I bought it and the speedo intermittently and the ABS light is on intermittently aswell. When I go on the brakes heavy the speedo will work occasionally for some time.
    I was told it needed a front drivers side ABS sensor?!
    How do you fit this? Its front drivers side!
    Still waiting on it to arrive
    Problem 2 - What is this
    You see the wee black pipe.
    It comes off the actuator then looks like it goes into a sensor then out off that..........
    No idea what it is?
    3-
    In the mornings or when the car is left you need to warm the glow plugs 4 or 5 times to get it to start.
    BUT if the car is warm it will start 1st/2nd glow
    I was told it may be fuel filter but not had the time to check.
    4- The LCD on the middle screen in the dial seems buggered its lit up yellow but not sure whats going on as all leds are lit up - Will i need new dials
    Thanks for the help in advance
    Dec 2010
    Inverness
    38
    I have joined 6 VAG forums and not one person has been able to answer any of my questions lol I am having no luck at all.
    I may just sell the thing....
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,949
    Give folk some time to answer!
    For problem 1 you need to scan the ABS controller with vagcom, as well as the instrument cluster.
    The speedo doesnt work off the ABS, it has a seperate sender on the transmission for vehicle speed.
    For problem 2 i've no idea what pipe you refer to, draw an arrow on your pic perhaps?
    For problem 3, have you checked that the glowplugs are actually working? Sounds like a couple of them arent.
    4, LCD's can be repaired depending on whats wrong with them. Have you tried pressing or holding down the reset button on the stalk?
    TD5 Land Rover Defender build
    Dec 2010
    Inverness
    38
    Thanks for the reponse mate
    1 - I got told by a audi speacilist its all linked the ABS light has the speed sensor as part of it. Thats why when i go heavy on the brakes the speedo works occasionally
    2 - Here you go
    3 Can i check them with a multimeter?!
    4 - What stock is the reset button on as i couldnt find it?!
    Sorry for the silly questions
    Thanks for the response mate
    "Stick a V8 in it!"
    14,949
    1. And i'm telling you the speedo sensor is on the side of the gearbox.
    2. Hmm ye i can see it now, not too familiar with TDI engines though so not sure what it is. If it goes to the actuator, then it probably should be going to either the inlet manifold or the airbox, after having passed thru the N75 valve?
    3. Perhaps, its just a heating element. Check for resistance between each plug and earth. You'll need to remove the wiring to do so.
    4. Its on the bottom of the right hand stalk.
    Dec 2010
    Inverness
    38
    1 - Is it easy to locate?
    2 - Where it sitting in the picture seems where it should be naturally if you get me. It was tucked under the coolant tank?!?!
    3- I will do this at the weekend
    4 - There is nothing under the wiper stock at all :-(
    Thanks mate
    "Stick a V8 in it!"
    14,949
    I've never tried to change one, but its on the nearside of the tranny, above and forward of the driveshaft iirc.
    Hmm, need to wait for someone more accustomed to TDI's. My only thaughts are that perhaps its supposed to connect to a vaccum resovoir, which is usually situated behind the passenger wing, or perhaps someones added it for a boost guage? Can you perhaps get a better quality pic of where it attaches to the engine, and the valve you mention?
    I presume your car doesnt have the full DIS then. Cars with a full DIS have a big LCD panel in the middle of the dash, which gives you various info such as fuel consumption etc, and some extra buttons on the stalk to flip thru the options. Does your car have four big lights instead?
    Maybe your LCD is just to display radio information? I've never seen a car with the older non-DIS cluster, so i've no idea whats supposed to be on the display.
    Dec 2010
    Inverness
    38
    Right I will have a check.
    Yep it has the proper screen in the middle of the dash but the LCD is dodgy on it.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,687
    1 - Not a clue.
    2 - Not a clue. Hard to tell when looking at the pics on a phone.
    3 - Cool.
    4 - Does your LCD look like this?
    A4 B5 Double Din, RNS-d, TMC, Full Sports Leather Heated with Leather Door Cards and Lower Door trims all for sale.
    Audrey's Build Thread
    RIP Audrey. She's being broken down.
    New Car, New Thread.
    Scott's Akoya Silver A8
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,687
    Quote Originally Posted by Connor_scotland View Post
    Dodgy like this?
    If so, then it needs replacing, fixing or bodging.
    "Stick a V8 in it!"
    14,949
    i dunno how you can have a screen but no stalk to control it?
    If it looks like Axios's pic, then you should have the controls on the wiper stalk...
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,687
    one wiper stalk with DIS controls.
    On the right hand side, see the reset button underneth and the lever switch on the side?
    Dec 2010
    Inverness
    38
    Axios - Its the exact same as your first pic
    As for it nto working the whole screen is glowing yellow like everything is lit up on the top half?!?!
    I have checked the stalk but nothing on it and its the original clocks and stalk?!?! I will check again incase I have not seen it.
    Thanks for all the help its much appreciated.
    Also the LCD does work as i press the dash buttons and it changes colour so its active just every part of its lit up - Will take a picture tonight and put it up.
    Hopefully ABS sensor comes today.
    Will a fault code reader pick up the no speedo issue?
    Dec 2010
    Inverness
    38
    Also how will i get the speedo working again.
    So its 100% NOT related to the ABS sensor a i was told the ABS sensor is the speed sensor aswell.....
    The reason i believed it was when i went hard on the brakes the speedo would work for a few hours then randomly stop
    The only problem i need/want fixed ASAP is the speedo issue.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,687
    Could be a lose connection.
    Part 9 is the speed sensor and its in the gear box.
    Dec 2010
    Inverness
    38
    Do they tend to go faulty?
    So if i jack the car up and go under it i will see the wires for the speed sensor?!
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,687
    That i dont know.
    Dec 2010
    Inverness
    38
    Hmmmm
    I found this and it shows the speed sensor at the wheel on number 3
    On more investigation its the ABS/Speed sensor
    I wonder by sorting that will it give me my speedo back.
    I hope its not a serious issue all i want is a speedo :-(
    I am using the Impreza until i get this sorted dont want my missus running about with no speedo - Was supposed to be taking the Audi to London next week doesnt look like it now :-(
    Dec 2010
    Inverness
    38
    You know what else is strange the speedo was working intermittently and i pressure washed the alloys/brakes and it stopped working completly..
    "Stick a V8 in it!"
    14,949
    There is a wheel speed sensor on each wheel, these are ONLY for the ABS.
    The vehicle speedo is driven by a sensor on the gearbox, and this signal is also sent to the ABS unit.
    If the gearbox sensor fails, its entirely possible you'll get an ABS light, because it can see the wheels turning but is getting no speedo input. I've never heard of one failing, but given its intermittant nature its entirely possible its a bad connection or broken cable or similar.
    You should be able to see it no problems from underneath. as i said earlier and as shown on axios' diagram, its just infront of the driveshaft on the nearside.
    Dec 2010
    Inverness
    38
    Thanks mate yea its strange its been intermittent.
    I will check underneath the car on Saturday for it :-)
    Thanks for all the info guys
    pjw
    Nov 2010
    Helensburgh
    203
    It sounds like someone has changed the clocks and failed to fix the speedo - but in doing so has fitted one with DIS. If you want original clocks PM me on here and ill trade you as im looking for some DIS ones.
    The speed sensor has nothing to do with ABS. The sensor is on the gearbox. Change it.
    As for the black pipe, unplug it and if the car runs, bin it. Could be anything.
    Change the glowpulgs, theyre about 3 each and as simple to change as sparkplugs. When you get the old ones out you can test them with a set of jumpleads to see how slowly they glow when 12v is applied. Brand new ones are instant and will sort the starting problem out. Dont bother with a multimeter, for the price just change them.
    Paul
    Purpur A4 B5 - -50mm - S4 Interior - RS6 Alloys - 3" Stainless Exhaust - K&N Intake - HID
    Dec 2010
    Inverness
    38
    The car is on a V plate if that makes a difference
    The milage,date,trip computer and back light and revs work fine just the speedo is a bit mental.
    Car runs fine with it unplugged, VERY economical.
    Yea think i will put new glow plugs in it :-)
    Have you a pic of the older dials? as my LCD for the DIS is all lit up - the top half is yellow but i assume thats a ABS sensor as then you press a button on the clocks the colour of it changes.
    "Stick a V8 in it!"
    14,949
    your wiper stalk should have the controls on it.
    Perhaps someones fitted an incorrect stalk?
    Dec 2010
    Inverness
    38
    Right checked the stalk thouroughly and no controls on it.
    The dials have never been changed either as when the engine was changed the dials stayed in the car.
    I wonder has the stock been broke before or something like that.
    The DIS screen works but shows no images or that just the lights change colour like something should be on the screen you know.
    Garage checked the car and said the speedo issue is the ABS/Speed sensor in the front right wheel causing the speedo not to work. The mechanic guy has a A4 :-) BUT i will wait till its fixed to pass judgement.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,687
    Get an image of your clocks for us to see and change that ABS sensor, since your not paying any attention to the poeple that you asked for help.
  28. #27
    Dec 2010
    Inverness
    38
    I am paying attention to the people on here just I am wanting it fixed so nipped over to the garage to see what they would say as i dont have time to get teh car over to the farm and on the ramps myself as my Impreza is in the garage getting new brakes ect ect
  29. #28
    pjw
    Nov 2010
    Helensburgh
    203
    Why surely..
    With DIS
    Without DIS
    Someones either swapped the stalks or the speedo.
    For the ninth time, the ABS sensor is nothing to do with the speedo. You probably just have a duff sensor which is putting the ABS light on. Buy one off ebay for about 17.
    Paul
  30. #29
    Dec 2010
    Inverness
    38
    Yea mine is "WITH DIS" BUT instead of an image on the screen its all lit up with nothing on it.
    Will the NON DIS dials just be a straight fit?
    Yea the car needs a ABS sensor anyways so waiting on it coming. Im putting it to the garage on Monday to get sorted i cant be arsed with it lol
    Im not saying any of you are wrong but i am looking at ALL things it could be. Just eager to get the **** sorted lol
  31. #30
    pjw
    Nov 2010
    Helensburgh
    203
    Yeah fair one, at least it will be guaranteed by te garage if they say they can fix it. i wouldnt take any jip off them if they replace the abs sensor though and it still has a problem, id just whine and moan until they sort it properly.
    Paul
  32. #31
    Dec 2010
    Inverness
    38
    The garage I use are decent they do the work on my Impreza and been using them for years :-)
    He said if wont give it back till its sorted and he lets me sorce the parts as i get them cheap cheap :-)
  33. #32
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Did you say the engine was changed? If so was this in your ownership as you seem to be adament that the clocks havent been changed, but if the engine was changed at some point for a 2nd hand unit, possibly the ecu and clocks were changed from donor car as a requirement for that engine to work hence not having the correct clocks/stalks. They will not be connected properly.
    Project RS28 build
  34. #33
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    Does your car have a digital clock? If so i think you will need clocks with a digital clock also. Im sure if the dis is just goosed you couls put a new display in,or just turn it off?
  35. #34
    "Stick a V8 in it!"
    14,949
    He cant turn it off as he doesnt have the stalk controls :P
    Either, someones changed the stalk and used a non-dis one, or someones fitted a DIS cluster to a non-DIS car and its lit up like that because its not wired properly.
  36. #35
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,364
    The speedo sensor is on the gearbox not the ABS sensor. You could remove the entire ABS setup and the speedo should still work.
    I would look for a blown fuse before condenming the dash etc. The Dis controls are at the end of the wiper stalk and a button on the underside HTH
  37. #36
    Apr 2004
    12,364
    The pics are not that clear but are you sure thats not the MAP sensor feed in the top pictures?
  38. #37
    Dec 2010
    Inverness
    38
    Hi All
    I called the garage who did the engine but he needs to check his paperwork to see what was all done.
    Byzan - Where should it be plugged into mate?
    Also where will i find the fuse for the speedo?
    Thanks lads
  39. #38
    hiltoa's Avatar
    VAG erfahren
    Jul 2006
    on the edge
    299
    The only sensible advice I can offer is to part/ex the car for a proper facelift A4 that hasn't been hacked about by Dr Frankenstein.
    Quicker and easier than trying to unstitch someone else's bad workmanship.
    IMHO.
    Nothing feels fast for long...
    2004 Audi Allroad 2.5 TDI L.E.
    Ebony Black.
    1991 VW Golf GTI 16v
    Tornado rot.
  40. #39
    Dec 2010
    Inverness
    38
    Well
    Replaced the ABS sensor and now the speedo is working perfect.
    2 New battery and fuel filter - Car starts first time now
    The thing in the engine bay is a mystery and will remain that :-0
    The wee screen isnt working so looking to swap gauges with someone as they dont seem to be for my car.
  41. #40
    Aug 2010
    1,540
    theyve changed something besides the abs sensor then! you can un-plug all the abs sensors and the speedo will still work!
    maybe theyve spotted that when the engine was changed theyve trapped the wires for the speedo sensor inbetween the gearbox and engine.
    that little pipe where does it come from/what is it attached to? looks like one of the vacuum pipes for the turbo/egr actuator system?
