Sky InsuranceEM Tuning
Results 1 to 10 of 10
    Cam
    Dec 2010
    Sheffield
    32
    Bleed Clutch slave cylinder
    Hi im new to this forum. ive recently bought an A4 1.8T quattro 1999 model. I tried to bleed the clutch slave cylinder with a gunsons eezibleed. It was on 10psi and the pressure cracked the brake master cylinder resovoir. Luckily the crack is near the top wich i have sealed temporarily with some silicon sealant. Does anyone know of a method of bleeding the clutch slave cylinder without using an eezibleed? Your comments will be appreciated.
    PaulTheo's Avatar
    Aug 2010
    Bristol UK
    126
    Use a vacuum pump on the bleed nipple. I did the same with less pressure than that the tank gets very brittle with age mine was about 7 years old got one free from a breaker be carefull when you fit the new one if its not new.
    Cam
    Dec 2010
    Sheffield
    32
    Thanks for your reply where can i get a vacuum pump. Ive never seen or used one before.
    PaulTheo's Avatar
    Aug 2010
    Bristol UK
    126
    Try ebay or a good motor factors the ones designed for bleeding have a tank that holds the fluid you draw off. They work very well and no leaks or mess. I hope you washed off any fluid that escaped when the tank went or you will damage the paint.
    Cam
    Dec 2010
    Sheffield
    32
    Yes i washed off the fluid. Ive just looked on ebay i think ive found the item you are suggesting. will you have a look at this link to check if it is the correct thing.
    Hand Held Vacuum Tester and Pump Brake Bleeder Kit Cars on eBay (end time 21-Dec-10 11:29:35 GMT)
    PaulTheo's Avatar
    Aug 2010
    Bristol UK
    126
    That will do the job also good for testing vacuum operated valves, sensors, hard to bleed brakes with abs and draning/sucking liquids out of difficult places.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,325
    just get a new resovoir and use the easybleed with less pressure
    The brake fluid will just dissolve the silicone and it will start leaking all over your paint work.
    I blew my first one by sticking 35psi into it. Since then i've managed to bleed it by keeping it around 8-10psi
    TD5 Land Rover Defender build
    Cam
    Dec 2010
    Sheffield
    32
    Thankyou for your messages.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,971
    This might explaine what happened to mine.
    My resovoir is cracked just above the fluid line, I was told it happened just after the new ABS system was fitted.
    I keep meaning to pop to Audi and pick a new one up (35) but never get round to it.
    8-10psi on a new resovoir will be ok?
    I've not looked in to how to replace the resovoir yet, I assume its just a lift off the old one and push the new one in?
    Is there a special way to bleed these brakes or brake bleeding option to run on VCDS?
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    "Stick a V8 in it!"
    15,325
    ye i just pulled it off, with a small tub to catch the fluid.
    Didnt even need to bleed it, as the fluid sitting in the stubs stops any air getting into the MC.
    Just bleed as normal.
    I've bled mine and Craigs S4 at 8-10psi and not had any problems. You can see the resovoir swell up though, even at 8psi. Its clearly very weak.
