Results 1 to 17 of 17
Thread: Will this work?
    Aug 2009
    Dorset, UK
    176
    Will this work?
    Please guys can someone tell me if this instruction i found on the net below will work with my facelift, W reg A4, or will I mess up the immobiliser.
    Procedure
    AUDI A8/S8: Programming the Key Fob
    Remote Control Programming (1997 ON)
    Procedure
    1. Switch Ignition ON and leave the key in the ignition.
    2. Mechanically lock the vehicle using the Drivers door using a second key.
    3. Using the remote control press the Unlock button once, and the horn will sound once.
    4. Wait 6 seconds and press the unlock button once to activate the coding
    procedure. The remote control will now be programmed.
    NOTE : When performing programming on additional remotes the procedure
    is the same, except you press the unlock button 2, 3 or 4 times for the
    different remote.
    For example : If programming 2 remotes press the unlock button twice with
    a 1 second interval between each press, repeat for 3 and 4 remotes.
    5. Switch Ignition OFF.
    6. Remove key from ignition and check for operation.
    7. The coding procedure can be repeated up to 4 times for additional remotes.
    8. The ignition must be switched OFF between programming each remote
    control.
    Remote Control Erasing (1997 ON)
    Procedure
    key.
    3. Press the remote control unlock button 5 times in 1 second intervals.
    A short horn will sound.
    4. Wait 6 seconds and press the unlock button once to activate memory
    erase.
    5. Switch ignition OFF, all remotes are now erased.
    __________________
    S8 1998
    http://pictureposter.audiworld.com/1...6022008202.jpg
    Thanks for any advice gents
    Aug 2009
    Dorset, UK
    176
    Now I have found this on the net, it is for an A4, has anyone tried this? My remote control/key fob has stopped working it has new batteries.
    Hope someone can advise.
    You'll need two keys.
    1) Open the driver door, turn the ignition switch to on, but do not start
    the car.
    2) Close and lock the driver door with the other key (this should be the
    proper key and not just the valet key - I used the valet key first and
    wondered why the programming didn't work).
    3) Hold down both buttons on the fob for about 5 seconds. The lights
    should flash and the alarm horn should honk.
    4) Open the door, remove the key from the ignition. Close and lock the
    door with the key.
    worked for my 99 a4
    james
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    The first method should work fine
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    I did mine about 2 weeks ago and it worked.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Aug 2009
    Dorset, UK
    176
    Thanks guys, Axios did you use the first or second method
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    Will this work on a b5.5 passat my remote fob opens the doors but immo light comes on when trying to start it . Ive been using the normal key to start ?
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,374
    You need to code the immo chip to the car, which requires the SKC and vagcom.
    Remote is completely seperate to the immo.
    TD5 Land Rover Defender build
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Quote Originally Posted by Nitro View Post
    That one.
    Quote Originally Posted by andybnwc View Post
    The procedure is to code the lock and unlock function of the remote not the immob.
    The immob light comes on when the little chip inside the remote (up the front near the blade) is faulty or not programed to the car.
    It will need to be taken to Audi or i think VCDS can do it, to get it programed to the car.
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    No, it's for coding fob to open doors, you'd need vag tacho/auto locksmith or dealer to code to immo
    kev
    90 eunos roadster
    Aug 2009
    Dorset, UK
    176
    Well I have tried both methods and they do not work on my car, any idea's what else to try next?. Could it be something in the alarm unit it self? How can you tell if the remote key fob has broken, or do i have to take it to a garage for that
    "Stick a V8 in it!"
    15,374
    Given it wont pair up, i'd suspect the fob before the alarm unit.
    You presumably have two keys, as you need two to do the programming? will neither of them program?
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Hows the batteries?
    Aug 2009
    Dorset, UK
    176
    Yes I have two keys one is the remote "flick Key" fob and the other is just a normal key. The reason I asked about the alarm unit is because if the alarm goes off the hazards flash but there is no sound at all. But that could just be the siren is broken?
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Mine never beeped or any thing at me.
    I carried on and it worked.
    "Stick a V8 in it!"
    15,374
    The siren is busted, but that wont affect the pairing.
    Which key did you have in the ignition? Is the key you had in the ignition capable of starting the car, ie has a matching immo transponder?
    Aug 2009
    Dorset, UK
    176
    Yes I had the Remote key "flick Key" in the ignition, and the normal key in the door. Both keys unlock and can start the car.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    The key you want to program needs to be in the door.
    I assume you want the flip key to unlock. so put the non-flip key in to the ignition and the flip key in the door and try again.
    My car never beeps when I set the keys up but the siren works, well, the horn in the back.
