finally got round to fitting the right click remote central locking unit. Fitting went quite smoothly, must say a thanks to aragorn who posted the following in an earlier thread:
On the box itself:
Orange and Orange/Black are unconnected
White is the close wire
Yellow, Yellow/Black and Black are all grounded
White/Black is the open wire.
There are two different pin choices depending on the age of the car:
White/Black goes to Grey/White, and White goes to brown/grey.
Grey/white will be either a) Pin3 on 12pin plug or b)pin9 on 16 pin plug
Brown/grey will be either a)Pin4 on 12pin plug or b)pin 10 on 12pin plug
It will be either both on a or both on b, not a combination.
Spliced, soldered and shrink wrapped the open, close and power wires and just grounded through a bolt in the rear cubby for holding the warning triangle. Worked 1st time!
I will try to get the blades cut locally but i might need a bit of advice on what to do with the little rfid chip. I only have 1 key with my vehicle and i dont want to butcher it for its chip and end up having no way to get the car started. i guess my 2 options are:
1) get a new "normal" key cut and matched to the car (who and where would be the cheapest do you think?), then cut the rfid out of that key;
2) order a new rfid chip and stick it in the remote key fob and match it to the car.
What would be the easiest/cheapest given that i dont have vag tacho but i do have a freeware veersion of vagcom and a willingness to give it a go. I remember an old thread where someone gave the type of rfid chip i would need but i cant find it at the moment, will need to do some trawling.
Thanks in advance..
On the box itself:
Thanks in advance..
