mattpanton
My rear washer jet packed up last week, just assumed something was frozen so kept trying it now and again, no joy, so tonight I decided to investigate further, found the culprit, a joint in the hose had popped apart, unfortunatly this particular joint was right above quite a large number of electrical multi-plugs behind the passenger footwell kick pod! All of which are now a bit damp, no electrical faults really apart from lots of interfearance on the radio when the heated rear screen is on which I'm assuming is a result of the wet, hoping everything will dry out ok!
Moral of the story is if your washer jets pack up, check those joints instead of doing what I did which was empty most of the contents of the washer bottle into the passenger footwell!
Sorry for the essay, hopefully this will help someone with the same problem in the future
