AH FabricationsEM Tuning
Results 1 to 10 of 10
    Aug 2010
    cornwall
    44
    afn limp mode list
    Hi, I'm working through "the list" in an attempt to cure limp mode on my afn, I've had a local garage check with vag com and all it picked up was 00575. so far i've blanked off the egr, and unplugged the maf to rule that out ( had to pull over and plug it back in after a couple of miles, as it was really flat!),I have just swapped the vacuum valve (n18?)that the egr is plugged into ( fixed underneath the hard plastic inlet pipe toward the rear of the engine) with the vacuum valve(n75?) that the turbo is plugged into( fixed behind the rad at the front of the engine) i wont know till i drive home tonight to see if its any different, is it ok to leave them swapped, are they the same valve?
    i know it has probably been covered in other threads, but i just want peace of mind, as i'm not really that knowledgable on engines ( i don't even change my own oil !!)
    thanks
    Neal
    TDIPOWARRR
    Jul 2010
    618
    Aug 2010
    cornwall
    44
    thanks Jack, i shall buy some mr muscle on the way home and give that a go tomorrow too. one more thing, how can you move the actuator rod, dont know what to pull?
    TDIPOWARRR
    Jul 2010
    618
    When you look down at the turbo the actuator is sat just above the turbo with a single pipe going to it, directly under the actuator is the actuator rod and you can just get your fingers in to move it up and down.
    Aug 2010
    cornwall
    44
    just as i thought,it doesn't budge!! although it doesn't help having fingers like pigs tits ! high hopes for Mr Muscle then. My n18/n75 swap didn't make a difference, still went into limp on the way home !!
    TDIPOWARRR
    Jul 2010
    618
    That will be your problem then i bet, sticking turbo vanes, the mr muscle trick is pretty simple to do, the guide evilscotsman did is easy to follow and the pictures hes put up help.
    Aug 2010
    cornwall
    44
    yeh thanks, read it through earlier. good write up !
    Aug 2010
    cornwall
    44
    just finished the job! I did what "evilscotsman" suggested and took off the two 10mm nuts holding the actuator to its mount, and pushed and pulled it for a while. Christ, when it freed i thought i'd broken it!! must have been really stuck!
    good excuse to go for a blast to the shop now, and see what difference it's made, fingers crossed for no Limp mode!
    TDIPOWARRR
    Jul 2010
    618
    Hope it's cured it, sounds like it was really jammed shut.
    Aug 2010
    cornwall
    44
    just got back and.....
    so much better! where as before i was getting consistent troubles at different revs and loads, now nothing!!
    thank you all again, virtual beers are on me !!
