Volks AutosChris Nott
    griswold's Avatar
    336
    Airbag light removal error 65535
    Right cant remove error with vcds
    after some searching found that I need a new/repaired airbag ecu
    found company on ebay who will do it for Ł25 inc return of my ecu.
    Also found this Volkswagen Audi VAG Air Bag airbag Reset Tool on eBay (end time 10-Dec-10 13:27:29 GMT)
    states it can erase dtc65535
    lists my ecu part number
    8D0 959 655 J (Bosch 0 285 001 276)
    Anyone know if these work or should i just send myairbag ecu away?
    A4 1.8T Quattro sport
    A6 2.4 Avant SE
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    65535 is a physical fault with the ECU itself. It cant be fixed with a reset tool afaik.
    1997 S4 - PPC ÂŁ999 Challenge Track Car Build
    TD5 Land Rover Defender build
    griswold's Avatar
    336
    Well gone for reset tool to try first to save me removing ecu some have had some success removing this code
    will probably have to change it though but tool will come in handy
    found this guide AudiWorld Tech Articles
    A6 2.4 Avant SE
    griswold's Avatar
    336
    Well got my reset tool and it cleared the code for now so lets hope it stays off
    hopefully it was due to the cold
    A6 2.4 Avant SE
