Sky InsuranceBadger5
Results 1 to 17 of 17
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    Retrofitting Cruise Control
    My 2000 w reg a4 tdi hasn't got cruise control,but my 2001 y reg a4 tdi breaker has,so i'm wondering how hard it is to fit the cruise control to the w reg?Both cars are ajm engine code.
    thanks
    tony
    Mar 2008
    Ipswichish
    127
    I think i's fairly straight forward, basicly swapping the stalks and a bit of loom and then recoding with vag-com, but i may be wrong
    '99 noggy blue S4 / '84 mk1 Astra GTE turbo
    CHRIS555's Avatar
    DOPE with added OCD
    Jul 2010
    Midlands
    1,941
    I think awesome-gti do this
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,390
    as tuffty says, swap the stalk and fit the pins into the ECU connector, then turn the feature "on" with vagcom.
    Not sure if the OEM loom will come out easily though
    TD5 Land Rover Defender build
    TDIPOWARRR
    Jul 2010
    618
    Axios has fitted cruise control to his b5, could have a chat with him on here and see if he could help.
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,031
    Yup, i've got the stalk installed but not had chance to do the wiring bit of it yet.
    Its on my ever growing wiring lift.
    You will need to remove:=-
    The small section of plastic around the steering wheel.
    Remove the clocks.
    You dont really need to remove all of the above but it will make it easier for you to remove the section of loom your after.
    But you will need to remove the steering wheel, stalks and lower section.
    I assume the CC wires are packed in with the rest of the cables from the stalk, if this is the case then you'll need to remove the CC cables from the main loom and carefully remove the pins from the ECU block (white i think). This will be a bit of a pain in the ass, so i'd opt for the other option of taking the stalk off the breaker and buy the loom from kufatec.de
    Its a simple plug and play in to your new motor and access to vagcom.
    Hope it helps.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Izzy1's Avatar
    Vorsprung Durch Technik
    Sep 2008
    Birmingham, UK
    348
    isn't there an issue of if the gas pedal is driven by wire or something?
    I've fitted one on my Bora (2001) as indicated, didn't realise the Audi (2000) would have the same process. thought is was a lot more tricky...
    Izzy
    Bora TDI sport
    Audi A4 TDI
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,031
    Quote Originally Posted by Izzy1 View Post
    If its fly by wire, then its plug and play.
    So I've read.
    "Stick a V8 in it!"
    15,390
    Yep, DBW is easy.
    Cable throttle cars are an arse, although i had the old FWD fitted up with cruise after a lot of messing about.
    Izzy1's Avatar
    Sep 2008
    Birmingham, UK
    348
    how do you know if your car if DBW or the other?
    Izzy
    Bora TDI sport
    Audi A4 TDI
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    all tdi's are dbw, most facelift petrol are except qts, petrols will have an epc warning light (electronic pedal control?)
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    dstructiv's Avatar
    Feb 2009
    34
    quick test for DBW is to accelerate as normal then press the brake with your left foot if the revs die off its DBW
    "Stick a V8 in it!"
    15,390
    I dont think that happens on all DBW cars?
    Feb 2009
    228
    It used to work in my old 1.8t, not tried it on the tdi...
    One thing i always wondered though is does this make 'heel & toeing' impossible in dbw cars?
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,031
    or just look for a throttle cable?
    I'm having issues with my CC wiring. Its doing my head in.
    I just can't get my head around it.
    I can wire in rear electric windows but not 5 wires for CC. lol
    pjw
    Nov 2010
    Helensburgh
    203
    The thing your on about above used to work in diesel cars as a fuel cutoff. Easiest thing to do is just look for a cable at the inlet surely?
    Paul
    Purpur A4 B5 - -50mm - S4 Interior - RS6 Alloys - 3" Stainless Exhaust - K&N Intake - HID
    foursprungdugtechnique's Avatar
    Jan 2011
    Perth, Scotland PH1 2BN
    279
    I was told to have the car in neutral, raise the revs to around 2000 and touch the brake pedal at the same time with your left foot, if the revs die to idle it's FBW
