Yup, i've got the stalk installed but not had chance to do the wiring bit of it yet.
Its on my ever growing wiring lift.
You will need to remove:=-
The small section of plastic around the steering wheel.
Remove the clocks.
You dont really need to remove all of the above but it will make it easier for you to remove the section of loom your after.
But you will need to remove the steering wheel, stalks and lower section.
I assume the CC wires are packed in with the rest of the cables from the stalk, if this is the case then you'll need to remove the CC cables from the main loom and carefully remove the pins from the ECU block (white i think). This will be a bit of a pain in the ***, so i'd opt for the other option of taking the stalk off the breaker and buy the loom from kufatec.de
Its a simple plug and play in to your new motor and access to vagcom.
Hope it helps.
