Chris NottAH Fabrications
Results 1 to 10 of 10
    floyd 1.8 turbo's Avatar
    Mirror, Signal, Outmanoeuvre
    Apr 2008
    Bracknell, Berks
    630
    Question Hello, i'm back again! Windscreen misting issue
    Since this lovely cold weather has arrived and its getting a bit damp, My windscreen keeps getting alot of moisture on the inside of the screen and so when its drops below minus it freeze's up on the inside. This also happened last year when the weather went ****. I close off the vents at night and put a cloth over the top vent on the dash but it still happens
    Anyone else have this problem????
    P.s
    My laptops broken again thats why i've not been on here of late, not that you'd probably noticed!!
    White B5 1.8 turbo sport
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,909
    Have you checked to ensure the scuttle drains arent blocked?
    It sounds like there is a lot of mositure trapped inside the car, either because the drains are blocked and rainwater has leaked in, or because the car doesnt get driven very far and your introducing lots of moisture getting in with wet feet etc but never letting it dry out again.
    Craigs S4 does the same, and its as far as i can see because he only ever drives it very short distances and never gets the car properly warmed up.
    TD5 Land Rover Defender build
    daz616's Avatar
    May 2010
    swanley kent
    39
    iv got the same problem with mine drives me mad in the morning got me thinking about a dehumidifier amazon have got some i might give one a go what do you think ?
    Amazon.co.uk: in car dehumidifier
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,876
    I have same problem it drives me nuts I was thinking on mine it was because it had a rac windscreen at somepoint in it's life but maybe not I do 35 miles a day in mine and still does it and the heaters are constantly on warm so I don't think it's due to short distances IMO think it's scuttle off job like you said Aragon !!
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Izzy1's Avatar
    Vorsprung Durch Technik
    Sep 2008
    Birmingham, UK
    348
    i've got wind-deflectors on mine and tend to leave the windows open slightly. few mm. never had a problem as they keep the car vented.
    Izzy
    Bora TDI sport
    Audi A4 TDI
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,357
    Have you got aircon?
    "Stick a V8 in it!"
    14,909
    I have AC, but it stays on ECON unless its actually needed.
    No steaming up here.
    Aug 2010
    2,876
    Yes I have air con and the econ button, when the econ light is on does that mean the air con is off or on as it sounds like air con cuts in as soon as I switch the control panel off with auto off ??
    jcb
    Sep 2005
    uk
    4,070
    change your pollen filter when you check the scuttle
    "Stick a V8 in it!"
    14,909
    The AC compressor runs when the ECON light is off.
    If you press the OFF button on the control panel the whole climate control system turns off, not just the AC.
