Monster MotorsportEM Tuning
Results 1 to 12 of 12
    bad-vw-boy's Avatar
    Dec 2007
    73
    Wobbly drivers seat...advise
    hi all ...just looking for some advise, my drivers seat has a slight wobble , any ideas what it could be...i know that in my vw's they use to have plastic clips which the seat would sit in on the runner and these used to get worn ...is it the same on the audi..
    1999 S4 B5 Avant........feel the power...
    flat out
    north weald essex
    220
    i'd like to know too, my passenger is always wobbling about so i assume my drivers does the same if i'm not in it
    Izzy1's Avatar
    Vorsprung Durch Technik
    Sep 2008
    Birmingham, UK
    348
    mine struggle to move on the runner. you really have to put some effort into moving the seats. passengers wose then drivers.
    Izzy
    Bora TDI sport
    Audi A4 TDI
    bad-vw-boy's Avatar
    Dec 2007
    73
    are the seats fairly easy to remove as no one seems to know about the runners?
    phoenixv6quattro's Avatar
    staylowmovefast
    Sep 2009
    wycombe
    1,395
    Seats are a doddle to remove! Remove the retaining pin at the front, remove the two plastic trims at the back of the rails and slide the seat backwards. Easy as that. You might find that the wobbling is due to play in the seat itself and has nothing to do with how there seated in the rails. If you look carefully you will see the joins on the bits on the seat that move (reclining etc). On mine, they are the culprits! Short of welding them up theres nothing that can be done really.
    IT COULD ALWAYS BE WORSE SO KEEP ON SMILING
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,350
    it does sit on plastic guides and they do wear.
    Drivers seat in mine wobbles like a goodun, I've looked under and you can clearly see the guide moving around. I need to get to the dealer and order some new guides, but i've been lazy.
    TD5 Land Rover Defender build
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    579
    My passenger seat rattles and squeaks like mad when there's no one sat in it and so would the drivers too I think if I wasnt sat in it. My squeaks and rattles all seem to come from where the seat back is attached tho...
    2000 1.8t quattro Sport totally standard (ish)
    "Stick a V8 in it!"
    15,350
    Mines defo the plastic guides from what i can see:
    YouTube - A4 Loose Seat
    staylowmovefast
    Sep 2009
    wycombe
    1,395
    I've had four seats in my car now and none of them ever had play in the rails/guides! Always been in the joins. Aragorn, you must have had some heavy arse bods sittin in that car at some stage! Lol!
    flat out
    north weald essex
    220
    interesting points raised.
    will have to get my head in the footwell on the weekend and diagnose it!
    "Stick a V8 in it!"
    15,350
    phoenix: rofl, its been like that since i bought it, only realised what it actually was a few weeks back.
    Seemingly the same plastic guides have been used for years, including on the old Audi 80/100 models, and its reasonably common for them to wear out causing the seat to rock like mine.
    '98 A4 2.4 SE
    Apr 2007
    Nr. Sheffield, UK
    99
    My drivers seat has rocked for ages, but this week it finally gave up the ghost entirely and now the whole thing lifts backwards!
    The welds at the front of the seat base have given up
    Time for a leather interior!! (but will buy some new plastic guides too!)
    Josh
