think of it as a book.
standard remap gives you the book off the shelf. all the info for increased performance based on your stock engine. a flash file that is plug and play. no dyno offered or required. Revo is a good example. if you dont like it you can buy the trial and have it removed 9although I hear that can feck up your car and actually lose power!)
next is a tweaked/custom remap, which is basically tweaked slightly based on a rolling road test to see how you car performs with the off the shelf map. it may change boost levels, timing etc etc albeit slightly it is specific to the mods or performance of your car. unless you have gone a long way from stock it probably wont increase the performance much from that of the "off the shelf" tune.
these are what most people get when they get a remap.
truly custom remaps come with stand alone engine management where the base file is really only there for you to drive to the dyno and have the rest of the "custom map" loaded based on the specific needs of the car/driver. they are not loaded with anything specific to any particular engine and are basically blank notebooks that you need to write in.
