Badger5Sky Insurance
    Jan 2009
    Brake warning light!
    Hi guys, I have the annoying brake warning light and accompanying 3 beeps on a cold morning. Looking around the forum, I see it has been a topic quite a few times and there is a known fix. I am looking for a part number for the required relay. Also a wiring diagram would be of great assistance as i plan to do the job myself.(I have an aversion to Main Dealer charges!!) Any help gratefully received.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,388
    Have you tried changing the bulbs?
    I've never heard of a relay problem, but presumably you mean the light monitoring unit?
    This is the unit fitted to most A4's: VW Audi Skoda No 387 Headlight Brake Warning Relay on eBay (end time 09-Nov-10 19:22:33 GMT)
    TD5 Land Rover Defender build
    Jan 2009
    Thanks for the reply aragorn. It is the red exclamation mark dash light that flashes three times along with the 3 bleeps.It happens on a cold morning due to extra current draw from the battery and I believe the fix is to fit some form of relay/circuit breaker to the signal wire running between the brake fluid reservoir level sensor and the dash warning light. I just need to find out what this relay thing is?
    "Stick a V8 in it!"
    15,388
    Hmm never heard of that at all sorry. The usual cause for the big three beeps is the ABS controller on its last legs.
    Road Razor's Avatar
    Tyne & Wear
    390
    I thought the exclamation mark was anything brake related. A few months ago I had the same warning and it turned out to be low brake fluid.
    A4 2.4 V6 2000.
