Monster MotorsportChris Nott
Results 1 to 12 of 12
    Apr 2009
    west London
    35
    S4 B5 Heated mirors..
    Hi there-can anybody tell me if the heated mirrors on my facelift S4 are always on? I assumed they only came on when the heated rear window was on(like on my old S2) but mine are always on! I had a slightly embarrassing experience a couple of weeks ago when my friendly MOT man became slightly less friendly as he leaned against my drivers mirror and yelped cos it was so hot! i assume there's a thermostat not working, but I was surprised it was on at all as the HRW was off?
    Any info greatly received.
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    Think pre-facelift are always on. Facelift cars only came on either at a particular temperature, or with the rear windscreen heater, can't remember which.
    Mo power, mo problems
    jcb
    Sep 2005
    uk
    4,077
    mine are always on (99 facelift),
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,372
    very early cars (95-96) had them hooked into the rear heated screen switch.
    Everything else supplies continuous power to the mirrors.
    Some people say that facelift cars have some sort of thermostat built into the glass, however this certainly isnt shown on any Audi diagram, and i suspect its there to kill the power once the glass reaches a set temperature, a bit like the cutoff switch inside a kettle, rather than to turn them on when its cold.
    TD5 Land Rover Defender build
    Apr 2009
    west London
    35
    Thanks for that everyone. I think there must be some sort of thermo cut out as the drivers side gets really hot and passenger is normal temp. At least its probably not a wiring fault that I really don't want to tackle...
    Thanks again for your help.
    GSB1's Avatar
    May 2006
    UK
    273
    Visit GSB1's Youtube Channel
    The later mirror glass has a thermostat on the back, it is plain to see. The glass does not heat unless it is cold enough.
    Present: Ice silver B8 S4 s-tronic saloon (standard)
    Past: Agate grey B5 S4 saloon (MRC tuned)
    Hers: Volcano red 8P A3 Sportback 2.0 TDI CR 170 sport quattro
    "Stick a V8 in it!"
    15,372
    Well mine certainly get warm even on the mildest of days.
    I suspect its a bi-metallic strip, designed to cut the power once the glass has heated up, rather than being designed to only power the glass up when it gets cold.
    jcb
    Sep 2005
    uk
    4,077
    ah, now by complete coincidence i just pulled one of these off today.
    there is a sensor about the size of three 5p peices stacked in one corner.
    the one I replaced it with didnt have one so I presume that it is dependant on the glass you put in them
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    Also the mirror adjuster has to be in the centre too i think
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    GSB1's Avatar
    May 2006
    UK
    273
    The thermostat (sensor or whatever) breaks the circuit, unless it is cold enough, then the circuit completes and the mirror element heats.
    GSB1's Avatar
    May 2006
    UK
    273
    Quote Originally Posted by jcb View Post
    Exactly. Early glass did not have this, original replacement glass you buy now should.
    "Stick a V8 in it!"
    15,372
    Interesting.
    It must activate at a fairly high temperature then, perhaps 10-15c rather than <5c.
    Its also unrelated to the mirror position switch. The power feed goes from the fuse box directly to the glass.
