Chris NottMonster Motorsport
Results 1 to 12 of 12
    AndyC's Avatar
    Apr 2003
    Dorset
    711
    B5 S4 Thermostat change
    Hey Guys
    got the usual slow warm up and in the cold not getting upto temp etc
    I am assuming the stat, as its got a new duel sensor already.
    is it possible to change without taking the belts off?
    any other tips etc?
    cheers
    Andy
    there is no such thing as bad weather, just the wrong clothes!!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,909
    Apparently you can squeeze it out past the timing belt with a bit of wrestling, but i've never done one personally.
    TD5 Land Rover Defender build
    AndyC's Avatar
    Apr 2003
    Dorset
    711
    was hoping that was the answer..... had to be somewhere awkward didnt it......... BALLS
    will add it to my list of things to do on the car....... its getting longer
    shineydave's Avatar
    Jan 2006
    Bradford, Yorkshire, UK
    904
    My S4 is just in for a Timing belt change, new thermostat, waterpump etc. i nipped down last night to see the progress. i'd be incredibly surprised if you could get to the thermostat without removing the belt, it really is buried in the back of beyond
    Dave
    "If that's the Turbo Fairy knocking tell Her I'm not in"
    Mar 2008
    Ipswichish
    127
    what is it with audi and thermostats, i did one on my old s3 last year and that was a pain in the rear to get to as well.
    '99 noggy blue S4 / '84 mk1 Astra GTE turbo
    AndyC's Avatar
    Apr 2003
    Dorset
    711
    Dave, I will pretend you didnt say that....... had enough of changing the whole rear bush set.... and suspension and brake lines this week................ grrrrrr
    shineydave's Avatar
    Jan 2006
    904
    Can i retract my previous comment, i spoke to Charlie at FA Ropers and he said it was possible but it was a pig. you have to loosen the front end so you can move the radiator etc forward and then when you put the new stat in there's hardly any clearance so it's a struggle to get the water gallery back in place
    Dave
    "Stick a V8 in it!"
    14,909
    Yep, someone on here has done it and posted up that it could be done without removing the belt but its a squeeze.
    I'd pull the whole lock carrier though to maximise access though.
    AndyC's Avatar
    Apr 2003
    Dorset
    711
    agreed, not that much more effort to remove the whole carrier though.... so YEA
    AndyC's Avatar
    Apr 2003
    Dorset
    711
    WELL!!!!
    Managed it........... changed the stat without removing the cambelt....
    the stat was stuck open, so never warmed up, was terrible especially in this weather... was using fuel etc etc etc
    dropped the carrier into the service position, left bank belt covers off. moved the belt carfully half off the pullies.
    you have to pry out the housing and its not easy..... plenty of room for error and to damage the belt if your not VERY careful.
    HAVING said that it took 3 hrs and now the temp is upto full in 2 miles........... so worth it................
    Andy
    S4twiggy's Avatar
    Fully Certified Detailer!!
    Feb 2009
    South Wales
    1,811
    Good to know it can be done andy, having the same problem with mine now so gona be changing in due course.
    AndyC's Avatar
    Apr 2003
    Dorset
    711
    the main advice is to take care with the belt......... also a good opportunity to flush and replace the coolant.
Tags for this Thread
