Chris NottAH Fabrications
    Nov 2010
    glasgow
    newbie in need of help
    Hey guys
    Just joined but have been a long time lurker
    I drive a totally standard 1.8t with 130,000 on the clock and have never had any probs until now.
    I've just been towed home after an apparent cv joint failure,the car did start making a clunking noise today from the passenger side which is the one the recovery driver said it was.But now it also seems that its going into gear without the use of clutch and there's some bad grinding noises when it does so.
    Any ideas whats going on?
    Is this consistent with the cv failure or am i looking at something bigger?
    Any help on this would be greatly appreciated as i dont fancy a new clutch/gearbox or both
    BASS 666's Avatar
    BMW aye right dead on..
    Sep 2010
    belfast
    463
    your cv joint being fcuked means you have no drive. if its notchy when you put it in gear the car is trying to drive but it cant cause the drive shaft is spinning in the cv joint. if its going into gear without any bother or noise then you have big problems mate..
    2002 1.9 tdi 130ish brake a4. full reiger body kit, 19 inch rs6 avant rims, eibach springs, home made grill, full leather interior, centre arm rest, quad powerflow exausts, a few engine mods, chrome door mirrors, aero wipers, s line door blades.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,386
    with a blown shaft you'll be able to shift without the clutch because of the synchros in the box.
    TD5 Land Rover Defender build
    Nov 2010
    glasgow
    Cheers for the replies guys.
    Still a wee bit confused though!Does this mean a new cv joint should sort it then?
    BASS 666's Avatar
    Sep 2010
    belfast
    463
    yes mate..
    Nov 2010
    glasgow
    Happy days dude cheers for that.Music to my ears
