AH FabricationsChris Nott
Results 1 to 8 of 8
    evilscotsman's Avatar
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    Dash bulb LED kit?
    Anyone seen an LED kit to replace the instrument cluster bulbs? I cannot believe it but not one listing on ebay....wtf?
    Mine are intermittently out / dim at certain patches - the diesel vibe usually wakes em up again but would like to swap them for leds (and all the tail, side and indicators too) as diesels like to bust lamps from vibrations more than others Id say and leds are tough.
    Dash kits tho, seem to be non existent for the B5 just want standard red ones as well!
    B4 TDI - old skool project / daily driver...if it ain't broke, it's probably an Audi...
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,324
    Early cars like yours have multiple normal bulbs, but they changed over to LED illumination in 97 or 98 and the LEDs are surface mounted onto the PCB.
    Presumably thats why theres no kits available!
    TD5 Land Rover Defender build
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    good point mate, but havent you seen the general purpose led kits they used to have on ebay, was for T5 wedges or something, I wonder if thats the kind of bulb shape fitted to the prefacelift dash? Come to think of it, probly more like T509's push and turn jobs...?
    "Stick a V8 in it!"
    15,324
    Ye they are pretty standard looking twist-in bulbs.
    Probably worth pulling one out to check the type.
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    If its got the lcd display in the middle the rest are solder in type leds
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    nah its not that fancy, no DIS in dis badboy (bad pun, but heh) just the trip and odometer are digi.
    It runs on coal.....lol
    "Stick a V8 in it!"
    15,324
    my '96 had a DIS and twist-fit filament bulbs.
    I know this because about 4 of them failed within about 100miles of each other, leaving huge swathes of the cluster in darkness.
    As i said above, all early cars have twist fit bulbs, LED's came in around 97, probably when they moved the immo to the instrument cluster.
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    nice one, thats a buy on ebay then!
    yeah mine is blacked out above the 100mph marker.....and half the clock.
