EM TuningBadger5
Results 1 to 7 of 7
Thread: Aircon advice
    Aug 2010
    cornwall
    44
    Aircon advice
    Hi, can anyone tell me why my aircon doesn't work when its cold outside!! just when you need it to defrost everything the aircon symbol will not stay lit and the compressor doesn't kick in when i press the button. yes the heater does blow out warm air when its warmed up, but that doesn't clear the windows,its ok when the weather is anything but frosty! I'm thinking it may be a sensor or something ?
    thanks
    PW-Motorsport's Avatar
    Jun 2006
    Pembrokeshire
    389
    Below 5 deg the aircon pump switches off.....
    bengal's Avatar
    Eskiv Champion
    Sep 2010
    Staffordshire
    537
    As above. There is nothing wrong its supposed to be like that check your handbook it will say in there. Hope this helps
    Aug 2010
    cornwall
    44
    numpty says thankyou. do i have to suffer **** demist then when its cold, its even worse with a car full of kids all talking and breathing, steams up real bad!!
    bengal's Avatar
    Eskiv Champion
    Sep 2010
    Staffordshire
    537
    Mines demists fine in cold conditions i normally put it on full heat though.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,324
    i think the misting up seems to happen more often if you run the AC a lot.
    Our old FWD didnt have AC, and it demisted just fine, similarly the TQS stays in ECON mode most of the time and also demists just fine without using AC, but i've heard a few people that use AC a lot that they find it hard to demist without it.
    Might be worth checking your scuttle drains to ensure they're not blocked. Blocked drains allows water to seep into the carpet and mean the car steams up really badly.
    TD5 Land Rover Defender build
    Aug 2010
    cornwall
    44
    thanks, i'll check my scuttle drains and persevere with it, thanks for the advice
