AH FabricationsChris Nott
Page 3 of 3 FirstFirst 123
Results 81 to 94 of 94
Like Tree14Likes
Thread: Un-Sticking Your TDi VNT Turbo Vanes.....
  1. #81
    Sep 2012
    Bamfurlong Wigan
    199
    Add scr8pdo on Google+
    How hard is it to remove the actuator arm so that I can test the actuator arm, if its a total nightmare I will use long nose pliers, thanks in advance, Ste
  3. #82
    Tolak's Avatar
    Sep 2013
    Somerset, UK
    111
    Based on similar Garrett t/c on different car:
    The actuator bellows has the vacuum tube entering one side, and the pull-rod coming out of the other side. This pull rod then drops down to the actuator arm on the bearing side of the turbo. So if you grab the actuator bellow like a ball, you should find the actuator shaft between your fingers, and you can then squeeze to pull the actuator up.
    Should move with less force than a tennis ball takes to squash, and then drop back to fully relaxed. If you hear air hissing, you might have a vacuum leak (tube) or a problem with the actuator (most unlikely).
    The vacuum is modulated by a trembler valve (identified as N75, above), so you get the amount of vacuum to achieve the scheduled turbo boost; if the control reaches full range without getting the boost, then the fault will be reported.
    Note that only the VNT/VVT is in the hot area; the actuator is almost 4" away, so much cooler, and the electronics of the trembler valve are well away from the hot area.
    HTH,
    Tom
    PAULF likes this.
    A4 B7 Cabrio 2007 2.0 TDi Black "Sport"
  4. #83
    evilscotsman's Avatar
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    very well put Tom.
    Folks, what sticks, is the ring the actuator operates on, and it usually sticks in the full boost position with the vanes closed (well pointing to the hotwheel / exducer) - hence when you use MM to soften and absorb the carbon, you should be able to get the actuator arm moving (which is actually moving the vnt ring and vanes inside the hot end. (MM = Mr Muscle)
    And its only needed if you get over-boost limp mode, on a VNT turbo diesel.
    also, never ever put MM in the intake side of the turbo!!! it reacts violently with aluminium and produces a toxic gas, never get it in contact with alloy. At least MM has a lower concentration than you may have made yourself, I never went into that before but you can make a strong version for pennies if you find MM cant shift the carbon cos its so thick....MM is Sodium Hydroxide, otherwise known as Lye, or Caustic Soda (as used in Biodiesel production - key element for de-soaping the veg oils) - you can buy caustic soda crystals in a number of places, and read the instructions. Always add the crystals to water, never the other way round, and wear goggles, gloves (and an apron if your a clutz) and inject the solution using a plastic paint mixing syringe and follow the original instructions after that.
    Sodium Hydroxide burns hot too so when it gets blown thru the cat, whats left of it ignites and helps clean off the mesh as well. My cat was cleaner than before after doing it. Its the only substance known to man which can dissolve carbon into itself apart from a chemical mixture called Piranha Fluid which is Hydrofluoric acid, and Sulphuric acid, a VERY VERY nasty combination, that even eats glass. Its used to clean carbonized glassware in a chemistry lab.
    jbh and Tolak like this.
    B4 TDI - old skool project / daily driver...if it ain't broke, it's probably an Audi...
  5. #84
    jbh
    jbh's Avatar
    TDi lover
    Slamannan/ Central Scotland
    635
    so Scott when are you doing the next chemistry lesson? what is it you do?
    1997 A4 Avant 110 TDi quattro
    1996 A4 Avant 110 TDi breaking
  6. #85
    Tolak's Avatar
    Sep 2013
    Somerset, UK
    111
    Quote Originally Posted by evilscotsman View Post
    Slightly worried about suggesting the use of this, especially if someone is a klutz!
    Also, it is typically better to try two iterations of a slightly milder (and safer) solution, because the effect is cumulative.
    But I agree with all the rest of your comments, and thanks for your kind comment.
  7. #86
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    lol cheers man, I'm an electronics engineer, in process control & automated machinery so I have worked in a few chemical plants or similar like paper mills, power stations etc and so you have to find stuff to work in some difficult areas, they use a list of preferred chemicals for certain tasks, like decarbonizing a large steam plant boiler tubes in a firebox. Thats how I found out about Sodium Hydroxide shifting carbon.
    The MM foam is easy to use if you get the bit right with the tubing (get it to the bowels of the turbo cast iron end) and get the foam to fill the hot wheel casting (brown cast iron end again for those that arent sure.)
    So to summarize, fill your brown end right up with foam so it touches every part of your ring and soaks your nozzles.
    (ooooh suits you Sir!)
    I've got it on my skin before and it doesnt burn readily cos its like 6% NaOH if you rinse it off fairly soon, but it works well after a couple of hours on the turbo. Too long, and its solvent evaporates and it starts to gel, if you do that by mistake then just add another filling of foam, wait an hour and then button up and blast it out on a run. The new stuff will turn the gelled stuff into liquid again pretty quickly.
    Raw caustic soda in pure concentrated liquid form is EVIL kids, its really bad stuff that instantly dissolves eyeballs and noses, it's as dangerous as sulphuric acid , its just at the opposite end of the PH scale. It turns body fat instantly to soap (true, thats how soap is made - chemistry lesson 2 LOL)
    Use the MM foam ok. Don't make your own.
  8. #87
    Tolak's Avatar
    Sep 2013
    Somerset, UK
    111
    So that's why we speak the same language; I'm a system engineer, coming from a software background, working in avionics, so describing a process, and understanding the reasons behind it, are my bread and butter.
    Strangely, this forum doesn't seem to be too wrapped up in the electronics controllers, and is biased towards mods and basic mechanical stuff, which is good. Just moved over from another forum (changed car) and there it was all codes and diagnostics.
    Anon
  9. #88
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    lol I get ya. I just like tinkering with 90's TDI's but sometimes things need more explanation. I try not to be too stuffy and have a laugh tho.
    Tolak likes this.
  10. #89
    Dec 2011
    Blackburn, Lancs
    21
    Evening,
    Just out of curiosity, would it be a better idea to get a blanking plate with a hole big enough to insert the 3mm silicone tube, cover the turbo from the exhaust side and fill it with Mr Muscle? This method apparently is also used, when using innotec.
  11. #90
    Jan 2011
    Aberdeenshire
    628
    That's essentially what I did with my 2.5TDis.
    Three nuts to unbolt the exhaust, tuck the tube behind the turbine, squirt and cover with cardboard - before the foam jumps out.
    A lot easier than trying to feed through and the result was still a freed-up actuator.
    Regarding Tolaks comment,
    As I see it, codes and diagnostic computers should be regarded as one more tool to assist in the driving experience - along with tape,penetrating oil and big hammers!
    Tolak likes this.
    1999 A4 B5 1.9 TDi FWD Saloon, Green
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine)
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
  12. #91
    Tolak's Avatar
    Sep 2013
    Somerset, UK
    111
    Quote Originally Posted by PAULF View Post
    Agree about using any hole to get the foam into the turbine. However, the inlet manifold upstream of the EGR and especially the head (upstream of the exhaust manifold) is aluminium, and so will be damaged if you put too much foam in, so the foam content needs to be measured/controlled in some way. Using top-down is easier, since the exhaust is steel, and only spillage upstream of the turbo is an issue.
    Driving experience, absolutely. But some of the issues are diagnosed with codes, and some with good old-fashioned mechanical skills, so those problems need everything we can use. Working out what the problems are, so all that remains is the "simple" repair, is the preferred route; these garages who swap one component after another (charging you at every step) are just making a mockery of diagnostic skills, and the customer's wallet. I would be much happier if they bore the costs of items found en route, so they could claim the benefit of their skills.
  13. #92
    Oct 2013
    Talking Sticking Turbo
    I have recently had this problem with my 1998 Audi A4 1.9TDi the Mr Muscle worked a treat on it.
    Many thanks for the info.
    Colin
  14. #93
    slizza786's Avatar
    Aug 2013
    123
    Sorry to revive an old thread but did your car have an egr cooler? What engine type was it? Bkd? My aluminium pipe goes from the egr valve to the egr cooler and then there's another pipe that goes from the cooler to the turbo which is extremely hard to get access to from the top and i tried already from underneath the car but the frustration got to me so I want to try another attempt from the top regardless of how long it takes
  15. #94
    Nov 2012
    27
    Quote Originally Posted by slizza786 View Post
    mine is 53plate, so has same cooler as yours, to get easy access like on those pictures i had to completely remove it (left it hanging on rubber pipes only).
