AH FabricationsSky Insurance
Results 1 to 17 of 17
    andysAko4's Avatar
    Oct 2007
    Ponty-carlo
    33
    How do you turn engine the over without starting it..stood for the last 18 months
    Almost ready to go back on the road after a few little mods, but want to get the oil flowing around her 1st so ?? I could jst unplug sparks but dont believe thats right..or is it
    BASS 666's Avatar
    BMW aye right dead on..
    Sep 2010
    belfast
    463
    let it start and idle. when its started the oil presure rises and feeds oil to all the places it should go to. you wont get the same effect if you just turn it over and over you will do more harm than good. why dont you want it to start ?
    2002 1.9 tdi 130ish brake a4. full reiger body kit, 19 inch rs6 avant rims, eibach springs, home made grill, full leather interior, centre arm rest, quad powerflow exausts, a few engine mods, chrome door mirrors, aero wipers, s line door blades.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    i'd just start it, but if your really worried, then remove the spark plugs, and unplug the fuel injectors, and wind it over for 10-20secs on the starter.
    TD5 Land Rover Defender build
    BASS 666's Avatar
    Sep 2010
    belfast
    463
    it doesnt matter how long it has been laying as long as there is a drop of fresh fuel and a good battery once he fires it up the oil will be up round it in seconds as long as he lets it idle for a while.
    sdk778's Avatar
    Jul 2009
    Gloucestershire
    44
    Agreed, drop a bit of fresh oil in the filler cap, good battery and away you go.
    Once warm, gentle increase in engine speed and then after a 10 mile run drop the oil and filter and get some fresh fuel into it.
    I would be of mind to whip the plugs out and clean them and also look at the other filters, air and fuel too.
    Should be fine though bud.
    2001 TT Coupe 225
    1997 A8 2.8 Sport
    2001 A3 Tdi SE
    1997 A3 1.8 SE
    beachbuggy's Avatar
    Surrey
    1,727
    if you don't want to start it just pull the fuel pump fuse. turn over for as long as you can before the battery goes flat. put the fuse back and start
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    Quote Originally Posted by beachbuggy View Post
    I second that just done it myself
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    "Stick a V8 in it!"
    14,900
    If your worried about the lack of oil, then remove the spark plugs.
    Winding it over with just the fuel pump disabled means the bearings that your worried about are all running dry against the compression of the motor. With the plugs out, theres vastly reduced load on the bearings, as theres no compression, plus the engine will spin faster, meaning the oil pressure will rise quicker.
    BASS 666's Avatar
    Sep 2010
    belfast
    463
    will someone please tell me why you wouldnt want the engine to start ? starting the engine gets the oil presure up in seconds and heats the engine up a treat on idle..
    evilscotsman's Avatar
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    most wear occurs in the first few minutes of starting up a motor but cranking the oil round is a good idea as the top end will be bone dry of oil after that long mate, but really not that big a deal if you used the car daily after its first start then only that one was a dry start anyway.
    B4 TDI - old skool project / daily driver...if it ain't broke, it's probably an Audi...
    BASS 666's Avatar
    Sep 2010
    belfast
    463
    thats my point cranking it over does put the oil up round it yes but when you start it the oil is up round it within seconds and it has a nice steady oil presure. i know its dry but but its not far off being the same as when it was started last. oil lays in the head and other parts anyway..
    "Stick a V8 in it!"
    14,900
    I'm of the opinion that if you just remove the fuel pump, and wind it over on the starter, then its not really any better for the engine than just starting it.
    If you are worried, then removing the plugs before winding it over is the only way to get the oil moving without subjecting the bearings etc to load.
    Once running, its a good idea to actually just drive off, rather than letting the engine warm up at tick over. Engines should not be warmed up at idle.
    BASS 666's Avatar
    Sep 2010
    belfast
    463
    thanks mate im glad someone agrees with me.. but i disagree about the idle bit, the cars been laying for 18 mths fcuk knows whats siezed up..
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    577
    If the engine was in good order last time it was used and left with a good oil level and a decent coolant mix in it, then I can't see why anything would be seized? I'd be more worried about damp/corroded electricals if anything
    Si.
    2000 1.8t quattro Sport totally standard (ish)
    BASS 666's Avatar
    Sep 2010
    belfast
    463
    i meant brakes and stuff.
    "Stick a V8 in it!"
    14,900
    yep, although it'd be sensible to check those over before trying to start the engine, so that once its running, you can take it for a spin round the block for a bit of a shakedown.
    Seems kinda pointless just to start the engine then stand there looking at it.
    BASS 666's Avatar
    Sep 2010
    belfast
    463
    he might stand and say, fcuk me it started lol....
