Basically when I switch the fan on no matter what speed it seems to stay at slowest speed could this be the fan or resistor as I no when resistors go they tend to only work on full speed and seems to have a droaning type noise also when it's switched on with air con off it seems as tho it cuts in cause engine revs bounce as though the pump puts load on engine is this normal on these ???
