alex-qts
My car is now in the garage as I am at uni and there is no parking in southampton! I have been having a problem with the car for a while now, let me start with what ive done so far.
New thermostat
New Radiator
Coolant Flush and New Coolant
New K04-015 Turbo
New Oil Feed Pipe
New 710n Diverter Valve - From TT?
Performance Panel Air Filter
Oil change - Semi-synthetic
The car smokes when pulling off, it chucks out blue smoke only when driving away. Even under WOT at any speed over 10mph it does not!! - It seems to throw out more smoke in reverse (this may be because I can see more smoke) Exhaust smells really strongly of fuel/something very similar to fuel anyway.
Car has done around 120k now hence the new turbo, my questions are:
Would the K04-15 without a remap be causing some kind of problem with the fuel - Air mix?
Would excessive crankcase blow-by suggest the PCV is faulty or more likely the rings?
If i need to rebuild the engine I can set my goals to do this but I dont want to do any work that doesn't need to be done!
I guess what I am really saying is has anyone got any ideas of what this might be, I am going to do a compression test ASAP to try and find out more.
Thanks for any help!
Alex
New thermostat
New Radiator
New K04-015 Turbo
New Oil Feed Pipe
Alex
