Volks AutosBadger5
    aidank1981's Avatar
    Nov 2006
    Shetland Islands
    251
    B5 Rs4 brakes under b6 s4 alloys on a b5 s4 anyone??
    Been searching threads but this gets a bit specific! I have an rs4 b5 front brake set up BUT am unsure about clearances under a set of 18" s4 b6 avus 6 spoke's on my b5 s4, there ET45's and are pretty close to even the standard callipers!
    Anyone running this? Can confirm if spacers are required and if so what size?
    Audi S4 Black on Black. 1999(T)facelift, Aluminium Mirrors, KW Varient 3 coilovers, AmD remap, uprated D/V's, 315bhp375Lb/ft torque, milltek down, 100cpsi cats an back, S4 B6 18" Oem runnin toyo T1-R's. Rs4 B5 front brakes still to fit...
    jcb
    Sep 2005
    uk
    4,077
    10mm spacers as a minimum. there is a guy on 246 that has them on his RS4 shod B5 S4, I believe he said you can just slide a rizla paper between them!
    just missed out on a set of 18" avus wheels on eBay
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,287
    The B5 RS4 calipers are quite a bit lower profile than the S4 ones, i'd recon they should go without too much of a problem.
    TD5 Land Rover Defender build
