Volks AutosMonster Motorsport
    norad97's Avatar
    Jul 2004
    75
    Disappearing-water Part 2
    Having put up with water leak for some time and unable to find, until now.
    I noticed water on the bell housing at the rear of the engine, a white crusty stanis as well.
    I used a camera probe with light to see,, I noticed the pipe at the flange is stained and looks
    in poor condition as well.
    It seems I would have to remove the flange as well, as I cannot see if its leaking.
    It seems that its a bit akward to change the flange, but doable.
    I notice that the hose is connected to the flange by some sort of wire clip???
    But when I spoke to the stealers it shows no wire clip, just a jublee clip???
    Has anyone changed this and had a clip in there pipe, or has it been upgrade to a standard clip.
    The hose is Ł30.00, what a rip off !!!!
    A4 1.8T Sport 1997 Ming Blue:Tan Leather:Bose System: Milltek System: K&N 57i:Hyperboost valve:Smoke rear lights units:Upsolute remap:N75J Valve:AWE boost Gauge.
    Jul 2007
    London
    3,238
    Done one of these a few days ago, was a 2L audi a4 wich is the same. The hose is held with a wire clip. Its the housing wich leaks most cases so get a new one, seal for it and also a seal for the coolant temp. sensor. Fiddly but doable, you will need some long nosed pliers though...
    norad97's Avatar
    Jul 2004
    75
    Hi, What about the wire clip,, the stealers dont have it listed.
    I am changing the hose and flange to be save, will have to remove some pipes as well
    looking at it.
    Looks akward but should be able to do it, have to feel for the flange bolts I guess.
