EM TuningSky Insurance
Results 1 to 7 of 7
    gaz71's Avatar
    1.8T Quattro Sport AJL
    Jul 2009
    Torbay
    287
    Headlight problem
    Was just checking to see why my passenger side headlight seems to jump every time I hit a bump and have found that the dipped headlamp section has come loose inside the unit. The main beam section seems ok.
    Can I fix this? (I couldn't see how to get the headlight apart)
    Failing that, has anyone got a spare one?
    To date - 2.5" Jetex exhaust, Generic re-map, Silicone hoses, N75k, shiny 17's, FK Springs
    Wanted - Sports cat, bigger downpipe, FMIC, Bigger turbo
    Mar 2008
    Ipswichish
    127
    the lens' are usually mounted on little ball in socket type mounts. chances are the ball has just popped out.
    From the back of the lamp try pulling the lens towards you and it should pop back in.
    '99 noggy blue S4 / '84 mk1 Astra GTE turbo
    gaz71's Avatar
    Jul 2009
    Torbay
    287
    Quote Originally Posted by Tuffty View Post
    So that would be pushing the lens towards the front of the car?
    Mar 2008
    Ipswichish
    127
    now you say it it does read that way, what i mean is pull it towards the engine.
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,922
    I have the same thing on me o/s lamp. The plastic scoket that screws to the reflector has broken. Trying to get a dontact for Depo now so I can sort a replacement, don't want to change a whole lamp for the sake of a silly plastic clip.
    Life begins at 140mph
    www.passionford.com
    Aug 2010
    EDINBURGH
    82
    ive got one for sale if you have a 97 shape b5 let me no if you want it tah scott
    TDi Powerrrr
    Aug 2010
    North Devon
    401
    i've got a facelift light if you need one.
    tony
