Chris NottMonster Motorsport
Thread: Clutch bleeding
    mattpanton's Avatar
    Sep 2005
    Suffolk, UK
    123
    Clutch bleeding
    Where would I find the clutch bleed nipple on a 2001 1.9 TDi B5?
    Also what is the brake bleeding order? I've heard nearest to furthest, but is this from the master cylinder or ABS module?
    2001 A4 Avant SE 1.9TDi
    Aug 2010
    1,540
    clutch bleed nipple is on the slave cylinder on the upper n/s of the gearbox.
