Sky InsuranceVolks Autos
Results 1 to 14 of 14
    audinary's Avatar
    Aug 2008
    Frinton-On-Sea
    646
    Long time no see, and CV joint.
    Hi everyone, I've been away for a while, nice to see all the familiar names still B5ing and welcome smattering of new ones, too.
    Last time I was here I was trying to get to the bottom of a strange noise, which finally turned out to be the n/s outer CV joint, which surprised all my techie friends at work 'cos they'd never heard one making quite that sort of sound.
    Anyway, I start the repair tonight. The Haynes Manual (yeah, I know, should have binned it ages ago) only gives steps after removing the driveshaft altogether. It being the outer one I'm fixing, can anyone suggest why I shouldn't do it with the driveshaft still in place? I know getting the CV off will be easier on a bench, but it would save a lot of skinned knuckles.
    Any of you guys who have done this operation before have any advice?
    Cheers, Chris.
    '98 Santorin Blue 1.8t Sport
    BASS 666's Avatar
    BMW aye right dead on..
    Sep 2010
    belfast
    463
    you will get more skinned knuckles trying to do it on the car trust me. for all the bother it is to take it out and put it in a vice. some cv joints come off really easy and some are a real nightmare so pray that yours is easy enough.
    2002 1.9 tdi 130ish brake a4. full reiger body kit, 19 inch rs6 avant rims, eibach springs, home made grill, full leather interior, centre arm rest, quad powerflow exausts, a few engine mods, chrome door mirrors, aero wipers, s line door blades.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    Its easy, undo CV bolt, then undo the pincg bolt and remove. Slide the shaft back to clear the hub. Wind the bolt back into the CV and it will press the CV off once almost screwd all the way in.
    Half hour a side tops if the pinch bot is free
    audinary's Avatar
    Aug 2008
    Frinton-On-Sea
    646
    Cheers chaps, Byzan; with the driveshaft still on the car?
    BASS 666's Avatar
    Sep 2010
    belfast
    463
    mate i have changed dozens off cv joints some on the car and some off the car and im trying to work out what your talking about cause it dosent make sense..
    Apr 2004
    12,520
    Bass 666, so have I, and the bolt drives the CV from the end of the shaft. Whether it make sense or not, it's the easiest way.
    BASS 666's Avatar
    Sep 2010
    belfast
    463
    so your trying to say when you put the bolt back into the shaft it goes right through the cv joint and hits the shaft and draws it off ??
    Apr 2004
    12,520
    Quote Originally Posted by BASS 666 View Post
    Bingo !
    BASS 666's Avatar
    Sep 2010
    belfast
    463
    before you undo the cv bolt its right in anyway so how can it draw the cv joint off when the shaft is clear off the hub ? cv joints arent hollow right through.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    Vag ones are.
    Before you undo the bolt, the hub stops it going right in and touching the shaft. With the CV out of the hub, it goes in further.
    TD5 Land Rover Defender build
    BASS 666's Avatar
    Sep 2010
    belfast
    463
    i stand corrected, i didnt know that vag joints were hollow cause if i did i wouldnt have been tapping them of with a hammer for all these years. it really is true u really do learn something new every day. thats a slap you owe me BYZAN A4..
    audinary's Avatar
    Aug 2008
    Frinton-On-Sea
    646
    Awesome! Cheers guys.
    Car is up on axle stands now, sounds like i'll be able to drive to work on monday in my own car rather than borrowing a rusty Ford Ka for the day.
    More fun in the freezing workshop than watching X Factor...
    BASS 666's Avatar
    Sep 2010
    belfast
    463
    i would rather let BYZAN A4 give me that slap than watch that fooking ****,,
    audinary's Avatar
    Aug 2008
    Frinton-On-Sea
    646
    Who wouldn't?!
