EM TuningJMB Retrofits
Results 1 to 19 of 19
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    Excess pressure in rocker cover
    hi,I have excess pressure in the rocker cover of my 2001 facelift 1.9 TDi.I'm thinking it might be worn rings,the mmileage is uite high at 246,000.Is there anything else I should look at?The pressure is so high that it is lifting the oil filler cap and allowing oil to escape.
    I notice there is a pipe from the rocker cover to near the turbo(maybe the egr valve?)
    thanks in advance
    tony
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,091
    Strip and clear teh breathers but at that mileage I wouldn't be surprised if you're suffering with ring blow by
    Life begins at 140mph
    www.passionford.com
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    thanks for the reply
    any ideas where the breathers are?am new to diesel power and still trying to work out where things are
    tony
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,091
    Sorry, have to admit I'm too offay with diesel motors, sure one of the chaps on here will be able to advise though
    www.passionford.com
    evilscotsman's Avatar
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    top o the motor mate, theres a big black plastic round bit, thats the pcv valve (positive crankcase vent) that leads to the intake. The valve itself must be blocked, its filled with steel mesh and gubbins but easy changed, just 2 hose clips. its pancake shaped, seen here on a golf engine but same thing. They called it a ccv valve here (lol) but its item 7 - well the thing at the end of the pipe that arrow 7 points too...
    B4 TDI - old skool project / daily driver...if it ain't broke, it's probably an Audi...
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    thanks for the replies
    I have seen the bit you are on about,will have a proper look tomorrow
    tony
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    even disconnecting it will stop the pressure till you get another one, will just smell a bit oily. If it blows oil out under boost after that, then the turbo bearing would have to be leaking from the pressure side into the crankcase but thats less likely.
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    cheers,will take it apart tomorrow and report back on whats happening
    tony
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    update
    couldn't get the rocker cover off because the inlet manifold is blocking access to one bolt.I removed the breather tpipe and nothing is coming out,so it would appear the filter in the rocker cover is blocked.Am going to see a mate who owns a garage and see if he has a solution to getting the rocker cover off without the need to remove the inlet manifold.
    tony
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    I think the filter pulls up out of the hole without taking the cover off but may be wrong, tho they usually do.
    jcb
    Sep 2005
    uk
    4,077
    PCV = Pressure control Valve IIRC but you may have a number of issues.
    if it has the pressure to lift the oil filler cap (a lot I would have thought!) and doesnt have the pressure in the crankcase/sump to push the dip stick out I would guess that it is originating in the head as much as it may be ring blow by.
    does it smoke at all on overun?
    drink oil at all?
    I would be looking at valve stem seals as well, as you can pressurise the rover cover through blown inlet valve seals but you would still see the oil consumption with the usual issues.
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    Quote Originally Posted by jcb View Post
    drink oil at all?
    it hasn't got the pressure to lift the dipstick.As far as I know it doesn't smoke on overun,and doesn't seem to drink any oil,just leak it out the oil filler cap.
    tony
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    pcv = positive crankcase ventilation
    Nov 2008
    Southampton
    58
    i have a similar issue on my 2000 1.8qts, it doesn't have the power to lift the dipstick but if you take off the filler cap there is alot of preassure under, the car is also smoking (blue) while driving off (not under WOT) the turbo and oil feed lines have been replaced so dont think its that but i am preparing for some engine work!
    what does this sound like?
    would a faulty PCV cause smoking, I am thinking it is the rings as its done quite a few miles!!
    2000 A4 Quattro T Sport
    K04-015 Turbo @ 1.0 Bar -- Panel Air Filter -- 710n Diverter Valve -- Stealth Boost Gauge
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    no the pcv feeds oily vapour / air into the intake, but not that much, and if it blocks, the pressure can blow external oil seals but cant cause smoking.
    more likely your rings are worn and the oil is getting past into the cylinders directly from the sump. A leaking turbo bearing can inject oil into the intake too and this also causes smoking.
    Nov 2008
    Southampton
    58
    I think it must be the rings because it was smoking like this before and after the turbo replace - im just praying its not the turbo really!! I have never done any proper motor work before but the car is garraged now, is it engine out to do the rings?
    I am thinking of going BT at some point, but want to get the motor sorted first, I suppose a compression test will tell me more about the general health of the engine! I need an excuse for that nice big V8 that I cant fit lol
    Thanks for your help!
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    no probs alex, yeah its an engine tear-down to replace the rings, and while its out you would do the tb, water pump, any gaskets and seals etc then theres the clutch if its not new, especially for big turbo power, standard clutches get fried lol but obv not necessary when repairing the rings.
    Turbo cars suffer from blow-by crank case pressure worse than na's due to the higher cylinder pressures etc when the rings are worn..
    jcb
    Sep 2005
    uk
    4,077
    at a push you can do rings with head off engine in, but to be honest if you are doing that much you may as well pull it and do some little things that you wouldn't otherwise do.
    why dont you do a leakdown and compression test with and without some oil/deisel in the cylinder (oil seals the leaking rings partially). would confirm or deny your suspicions before you start pulling engines out.
    Nov 2008
    Southampton
    58
    i am currently at uni in southampton and the car is back in london, as soon as i am back i will try to do the compression tests, i have never pulled an engine before so this may be interesting! the most i have done is fitted a new radiator and turbo pipes, could you recomend anyone who would recon the engine for a good price?!
