    Sep 2010
    Unhappy A4 Turbo replacement.
    I have just found this site and hoping for some info. I'Ve had my turbo cut out a couple of times and the Audi garage diagnosed a fault with the waste gate actuator, they say a new turbo is required. It is a 1.9tdi sport on a 53 plate with 26,000 miles only. It seems a bit early in its engine lifespan to need a new turbo, so I wonder if anyone else has had a similar problem.
    Jan 2004
    York
    1,657
    You might be better off asking this in the B6 section if it's a 53 plate. Also try an independant VAG specialist garage as well.
    MY15 8V S3 Sportback with options
