Sky InsuranceChris Nott
Results 1 to 10 of 10
    Dec 2004
    Rancho Cucamonga, SoCal
    10
    Boost Gauge/Pod ?
    Is there any reason I shouldn't get this for my 01 A4?
    http://www.newsouthperformance.com/pod.htm
    Thanks.
    imported_ZeroK66
    Re: Boost Gauge/Pod ?
    Thats quite cool... pity it blocks the DIS though...
    I use my DIS for SAT Nav, so I couldnt use it. [img]/ubbthreads/images/graemlins/frown.gif[/img]
    Dec 2004
    10
    "I use my DIS for SAT Nav"
    Hi, explain please for a humble immigrant noobie.
    May 2004
    Billericay, UK
    278
    Some of the Audi SAT Nav systems display directions on the screen between the Rev Counter and Speedo (the DIS - Driver Information System)
    Greg
    Jun 2003
    Chicago, US
    115
    I know someone who has it, and the only thing I could think of as a reason "not to get it," is that is partially blocks your center display a bit. Thats it really, other than that, the pods work well...
    Dec 2004
    10
    Thanks Guys. I ordered one, a vdo boost gauge and drop in k&n filter. My first mods.
    imported_VaulterTim
    On that topic...
    What's the best one and the best place to get a boost guage in the UK guys?
    Tim
    Danielson's Avatar
    Jun 2004
    UK
    704
    u could buy a cheap gauge like mine, and custom fit it anywhere u want...
    imported_VaulterTim
    Where is the guage attached to? I mean the pipe that feeds it from the engine bay...
    Dec 2004
    10
    I've got the gauge and pod installed as well as the K&N [img]/ubbthreads/images/graemlins/beerchug.gif[/img] however I would liek to flog the engineer that hid the filter away that much [img]/ubbthreads/images/graemlins/burningmad.gif[/img]
    Where are you Guys taking power and ground from to power the lights on the gauge.
    Also I am boosting ~10psi is that okay and what is it supposed to be if there is something wrong with my numbers.
    Thanks.
