Volks AutosJMB Retrofits
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    Coolant tank plug
    Has anyone got a spare plug with a bit of cable on it ? If not can it be bypassed temp just while i run the engine for testing ? The wire has broken at the connection at the plug so no spare cable to fix it
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,385
    Why does it need bypassed for "testing"?
    TD5 Land Rover Defender build
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    Just to stop it pinging and flashing at me while i run vagcom , the car hasnt been run for over a year now , the least warning lights the better so i can concentrate on the real problems .
