Chris NottSky Insurance
Results 1 to 14 of 14
    205man's Avatar
    May 2006
    worcestershire, uk
    1,016
    looking for new springs - anyone tried these?
    im looking for some new springs for my 2.8qs as i mentioned the other week, ive found these has anyone tried them or what do we think?
    as ive already go the quattro sport suspension fitted will these make it look much lower ? im looking for more cosmetic than trying to make it like something for track days lol
    FK LOWERING SPRINGS AUDI A4 B5 QUATTRO 4x4 94-01 35MM on eBay (end time 26-Sep-10 19:20:41 BST)
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,389
    FK stuff is reasonable quality. I wouldnt say its up there with the big names like Eibach, Koni or Bilstein, but its not scraping the gutter either.
    Your Quattro is probably already about 15-20mm lower than "normal", so expect an extra 15-20mm from those springs.
    My only worry would be that they dont have different kits for different engines on quattro models.
    TD5 Land Rover Defender build
    205man's Avatar
    May 2006
    worcestershire, uk
    1,016
    I had thought about the fact they only list quattro as a generic spring to all engines
    But then thought how do we know that other suppliers don't do the same but just put a slightly different part number on and sell for twice the price lol
    what's the weight difference say between the 1.8t and 2.8 ?
    May 2006
    Sunny Isle
    265
    Be intresting to so how these performed and what drop they would give cars with the sport suspension!.. I wish they would list the lowering rates properly!
    "Stick a V8 in it!"
    15,389
    Theres about 50kgs between them i think.
    My handbook says kerb weight for the TQS is 1490 and kerb weight for a 2.8Q is 1540.
    I would imagine the front springs will be somewhere between 200-300lb-inch, which means you could be talking 10-20mm difference depending wether they're designed for a 1.8 or a 2.8.
    I would hazard a guess that they're for a 2.8 though, as 1.8 quattros are relatively rare when compared with the whole B5 production run.
    May 2006
    Sunny Isle
    265
    so they might not even lower a 1.8t tqs ?
    "Stick a V8 in it!"
    15,389
    Exactly.
    You just dont know where in the range they've aimed for. They might have gone somewhere in the middle, so you get a bit more than the specified drop on a V6 and a bit less on a TQS. Suck it and see i guess.
    Jul 2008
    Birmingham
    629
    Lolz... ~100 and a day's work to find out it raises your car 2mm and your car now handles like ****... no thanks. :P
    A4 1.8TQS
    "Stick a V8 in it!"
    15,389
    Well thats the whole point isnt it...
    You either spend lots of money on a kit thats going to work, or buy a cheap kit that may or may not do what you want.
    flat out
    north weald essex
    220
    fit some jom coilovers if you are going for a cheap solution
    May 2006
    Sunny Isle
    265
    no joms for quattros available (well not that ive found)
    In fact theres next to bugger all kits for the quattros that ive seen that would be any good..
    CraigG's Avatar
    May 2008
    188
    H&R, KW, Bilstein, Eibach etc etc etc...
    Imola S4 - Bilstein B6 + Eibach Prokit, Anthracite BBS Pescara 18x7.5"
    May 2006
    Sunny Isle
    265
    But do they list the lowering rate for the sport suspension ? or the same as others
    "Stick a V8 in it!"
    15,389
    Very few manufacturers will list the lowering rate.
    The springs are progressively wound quite often for starters so they dont actually have a single rate, but if you think about it, its their "recipe". They're not going to publish the spring rates, because thats what they've spent the money developing.
