JMB RetrofitsAH Fabrications
Results 1 to 8 of 8
    gaz71's Avatar
    1.8T Quattro Sport AJL
    Jul 2009
    Torbay
    287
    Bloody wheel bolts
    Just went to fit new wheels and the fronts are locked tight.
    The new bolts are angled fitment and 27mm thread.
    Back wheels rotate ok.
    Any ideas why the fronts are locked up while the backs are fine?
    What would be the best solution - use old bolts, shorter bolts, cut bolts to length or 5mm spacers?
    The new bolts appear to be about 5mm longer than the originals (radius fitment)
    To date - 2.5" Jetex exhaust, Generic re-map, Silicone hoses, N75k, shiny 17's, FK Springs
    Wanted - Sports cat, bigger downpipe, FMIC, Bigger turbo
    Faster in reverse
    May 2010
    Stirling
    70
    i had the same problem when i fitted longer bolts. the only options are put a nut on them and cut them down. or get shorter ones
    Robbo
    gaz71's Avatar
    Jul 2009
    Torbay
    287
    Does anyone reckon these will sort out my problem?
    eBay - The UK's Online Marketplace
    Faster in reverse
    May 2010
    Stirling
    70
    yeah they should solve your problem, but the cheaper option is to cut your bolts down, or use the old ones
    Robbo
    gaz71's Avatar
    Jul 2009
    Torbay
    287
    Was thinking of using old ones but they a radius fitment and the new ones (and wheels) are angled. Surely the bolts should match the wheels for a tight fit?
    Not sure about cutting bolts down, don't want to risk threading the hubs if I don't get it just right
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,385
    I'd cut em down.
    Spacers are just a bodge, and its the wrong fix for your problem.
    TD5 Land Rover Defender build
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    as above chop them but yes radius-radius and pitch-pitch
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    gaz71's Avatar
    Jul 2009
    Torbay
    287
    Right, now where did I put my hacksaw
