- Joined
- Apr 27, 2003
- Messages
- 711
- Reaction score
- 5
- Points
- 18
- Location
- Dorset
- Website
- www.k-tecracing.com
Ok......
A friend at work has lots of Evo's, he has brought in some calipers.............
they are light, pad choice is massive........
believe it or not they "almost" fit as they are....... if one hole is bolted the other is 3mm out....... BALLS>>>>
the disc offset is almost the same...
Having had it all off, if the calipers are extended so a rear mounted extender bracket is used it brings the caliper out about 22mm.
I am hoping the disc from the S4 with the 345mm disc will go on and away we go.....
its a cheap 4 pot conversion............
info to follow unless someone knows more on this one.
Andy
Andy
