EM TuningMonster Motorsport
Results 1 to 16 of 16
Thread: Silent Alarm
    gaz71's Avatar
    1.8T Quattro Sport AJL
    Jul 2009
    Torbay
    287
    Silent Alarm
    I've just noticed a sight issue with my alarm.
    I triggered the alarm while messing with the car but only the indicators are flashing, there is no audible warning.
    Has anyone got any ideas what would be causing this
    I didn't see any codes the last time I scanned with VagCom but will recheck for fresh codes.
    To date - 2.5" Jetex exhaust, Generic re-map, Silicone hoses, N75k, shiny 17's, FK Springs
    Wanted - Sports cat, bigger downpipe, FMIC, Bigger turbo
    evilscotsman's Avatar
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    im sure its to do with the settings in vag com mate, I know some other cars can have the beep disabled depending on which country code you chose for the settings, alfa beep unless you set it to australia, which is done by pressing the bonnet pin-switch 3 times then holding it till it beeps, then each press after that selects a diff country.....dunno if thats much help but check vag com anyway for codings in the immob and alarm. Audi beeps will probably be in the coding in the module, accessible from vag com.
    B4 TDI - old skool project / daily driver...if it ain't broke, it's probably an Audi...
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    most likely knackered siren, very common fault
    facelift use a battery back up type and the batteries eventually leak which wrecks the rest of circuit board
    bargain at 80 from audi !!!!
    i got a used replacement from a later model from A8 parts, slightly different design but works perfectly, pretty sure it had the same part number but with an 'A' suffix
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    jcb
    Sep 2005
    uk
    4,077
    you can have mine, I took it out when the battery died and it started going off at 3am.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,521
    I am sure Aragorn has recently fitted one of these upgraded units. Aquired it from Ebay.DE IIRC
    gaz71's Avatar
    Jul 2009
    Torbay
    287
    Quote Originally Posted by jcb View Post
    That would be great
    PM sent
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,379
    Whats the point fitting a broken one lol?
    ebay.de has lots listed, so i picked up one of the upgraded types from a new A8 and fitted it last week.
    I now have my lock "chirp" and a working siern!
    Alarmsirene 605 A Angebote - attraktive Preise fr Auto Motorrad Teile, Audi Artikel bei eBay.de
    TD5 Land Rover Defender build
    gaz71's Avatar
    Jul 2009
    Torbay
    287
    Silly question but where is the alarm module located on the B5?
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    below c/l pump, offside boot compartment
    try a8 parts first, only cost 25 plus postage
    wouldnt bother with an a4 one as they arent designed to last 10 years plus
    kev
    90 eunos roadster
    "Stick a V8 in it!"
    15,379
    B6/7/8 all use the same part (well the revised "A" part anyway) as do most other Audi/VW cars so you can get it from anything new.
    wayne77's Avatar
    Mar 2007
    burnley,lancashire
    77
    aragorn is there any modification needed to fit one of these newer units as mine is also silent on my 99 s4 avant, or is it just a straight plug in jobby
    cheers
    "Stick a V8 in it!"
    15,379
    you need to swap the bracket over, but that doesnt really count as a mod as its just a single bolt :P
    wayne77's Avatar
    Mar 2007
    burnley,lancashire
    77
    cheers mate thank you
    gaz71's Avatar
    Jul 2009
    Torbay
    287
    Quote Originally Posted by olds_kool View Post
    Hi have you got the part number for the siren?
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    same as old one but 'A' on the end
    kev
    90 eunos roadster
    Oct 2010
    Hi Im havin the same issue and have purchased a new siren .... Could someone please let me know (or with any images) the exact location on an a4 cab (2003 model) some sites ive seen have said left side rear and some right. I wanna replace it myself but just need to know where to start to get the old one out ! very much appreciated.. cheers
