had the front seats out today on myw reg tqs for valetinig ,now the airbag lights on ,disconnected the battery but still on , how do you rest it
been told you need computer hooking up to get rid of it, something to do with error code being flagged up on ECU, needs clearing with either fault code reader or comp with VAGCOM or some jazz.
Dont piss around with a code scanner, they're useless, get yourself a vagcom lead.
You can either buy the real deal for £200ish, or buy a clone cable from ebay for a tenner and run the software in free mode.
For Sale: Breaking B5 S4 - Lots of parts Available!
Wanted: Facelift A4 Front Bumper with Headlight Washers.
2000 A4 1.8T Sport Quattro Avant, Beere Pearl, TT Carriers and B6 312mm Disks.
2000 A4 1.8T Sport Quattro Saloon, Black-ish, Now Running!
1997 S4 - PPC £999 Challenge Track Car Build starting soon!
Audi V8 powered Land Rover Defender build in progress.
if you need to remove the seats again, disconnect the battery first and wait 15 mins before pulling the connectors under the seats, they go to the srs (seatbelt restrain system) which is part of the airbag unit and will always trigger the error light.
1.9 TDi 110 RedEye - Vulcan Black Pearl (LZ9U) - Silicon Vac Lines, Relocated N75, EGR Delete, VNT Turbo Clean by Mr Muscle, 2" JCB Hydraulic Hose Inlet Rubbers...50 MPG
JDM Legacy GT 2.0 Quad-Cam Twin Turbo AWD - 301 bhp - Dark Green Mica - Full H&S Stainless 3" Decat...22 MPG
The car will have side airbags, which are mounted in the seats, if its newer than ~97.
