After some opinions guys.
Driving home from work this evening I noticed that at times I am getting vibrations through the clutch pedal it gets worse at higher rpms when you lift off the accelerator, when you apply some "gas" it pretty much goes away. Also when stationary you can hear the clutch which stops when the pedal is depressed. The clutch doesnt seem to slip so I am guessing this is probably the dual mass flywheel at fault?
