JMB RetrofitsAH Fabrications
Results 1 to 8 of 8
    54
    Facelift avant immobiliser problems
    I've started having problems with the keyfob on the avant, the first time I go to the car and try and unlock it using the keyfob nothing happens. I then unlock it with the key, put the key in the ignition to stop the alarm going off and the whole car unlocks. Once I've finished the keyfob will lock the car and it normally works fine for the rest of the day, but the same problem returns if the car is sat for a few hours
    I've changed the batteries in the keyfob and that's made no difference.
    Is my keyfob on the way out? I take it only Audi can supply and code a new keyfob for ŁŁŁŁŁ
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    what happens if you just unlock it with the key streight off?
    The door lock has a microswitch which should disable the alarm, and open the rest of the doors? If it doesnt do that then the microswitch is busted and needs replaced.
    Perhaps theres two seperate issues here, one the remote playing up, and the other being the drivers door lock switch being faulty.
    The remote and the key are seperate, you can get a matching remote and code it up yourself, but you need two keys.
    1997 S4 - PPC ÂŁ999 Challenge Track Car Build
    TD5 Land Rover Defender build
    54
    Sounds like the door lock microswitch is knackered as it'll only unlock the drivers door with the key and the alarm will go off if you don't put the key in the ignition. Once you put the key in the ignition the rest of the car unlocks.
    I've been busy swapping over to xenon headlights this morning and the keyfob has worked flawlessly since I put the new batteries in this morning, will have to wait and see if the new batteries have fixed it.
    "Stick a V8 in it!"
    15,370
    So it sounds like two seperate issues then.
    I'd say try unlocking it from the passenger door, but that only works on PFL's :P
    Its probably worthwhile getting yourself another key anyway, one key isnt a good idea.
    54
    Looks like it was just the batteries in the fob as since I've changed them it's been fine.
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    your cars behaving as it should
    using the key in drivers lock on a facelift will not pop the rest of the locks and the alarm will go off if you dont turn ign on straight away (then rest of doors should unlock)
    all facelifts are remote c/l so key lock is just in case it fails
    have you been pressing fob buttons when car is out of range? as that will disable fob untill you re sync by pressing fob then starting car which you did anyway
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    54
    Quote Originally Posted by olds_kool View Post
    Ah, that's probably it then, the range on the keyfob is lousy!
    "Stick a V8 in it!"
    15,370
    Didnt realise facelift cars wouldnt properly unlock from the key, thats a bit crazy!
