JMB RetrofitsSky Insurance
    evilscotsman's Avatar
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    TDi Shudder when idling
    Gaaaaah! If its not one thing, its something else. It's now started shuddering from left to right when I stop at idle, when hot. Anyone throw any light on this?
    I do have a diesel leak from the base of one of the injector pipes but at the pump end, bottom one nearest the block I think, looks a ***** to reach for tightening. I dont think this is the cause, more like an electronic engine mount but dont think a 96 motor will have them will it?
    If you switch off for a minute, then restart, the shudder is gone, and only appears at idle anyway, even 1k rpm its as smooth as butter, but at 800 idle its rough sometimes.
    B4 TDI - old skool project / daily driver...if it ain't broke, it's probably an Audi...
    Jul 2007
    London
    3,235
    DMF on its way out mate...
    FOR SALE:
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    its a 96 motor mate, did they have dmf's that early?
    Jul 2007
    London
    3,235
    If its a 90Bhp it had single mass, if its 110 then more likely DMF. I would check the smooth running on the cylinders with VCDS/vag-com in measuring blocks nr 13. If they all close toghether then it does not point to a injector missfire. You could also check the cylinders pressures with a Diesel pressure tester...
    FOR SALE:
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,368
    I'd be fixing the leaking high pressure line before condemning the flywheel...
    TD5 Land Rover Defender build
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    yep sounds more likely mate, looks a ***** to get to, any procedure to know before cracking the unions off? ie there shouldnt be any residual pressure in a Di system should there, unlike a common rail?
