JMB RetrofitsSky Insurance
Results 1 to 7 of 7
    Apr 2009
    41
    How to know if the valve seals need done?
    had an oil leak on my 2.8 V6 for ages, didnt really have the time to have a look before today, looked at the usual valve seal area, there appears to be alot of black gunk around the seals so I am assuming this is where the oil is comming from.
    only issue is it only leaks when the car is flat, if it is parked with the nose raised then it doesnt leak.
    dont want to shell out for some seals if thats not the real problem.
    links are show the valve seal area.
    IMG_0207 | Flickr - Photo Sharing!
    IMG_0206 | Flickr - Photo Sharing!
    cheers
    jcb
    Sep 2005
    uk
    4,077
    you mean "valve cover seal" = easy swap. looks like you need a new gasket, get a decent cork one from Reinz or similar branded goods
    "valve seals" tends to refer to the valve stem seals inside the head which is a much bigger job.
    Apr 2009
    41
    ahhh yes, sorry valve cover seals, eurocarparts have them, just unbranded, best to avoid?? (there 36 each)
    evilscotsman's Avatar
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    its just a one piece rubber or cork gasket mate, nothing special required there, its not under pressure like other parts of the engine. Any make will do. I wouldnt be payin bloody 36 for a rocker gasket tho lol. Check ebay, for rocker cover gasket or valve cover gasket.
    B4 TDI - old skool project / daily driver...if it ain't broke, it's probably an Audi...
    Apr 2009
    41
    Quote Originally Posted by evilscotsman View Post
    hmmm can only find ones around the 30 mark, the 4 pots are cheaper, the V6s seem to be very expensive!!
    tux
    tux's Avatar
    May 2010
    Notts/Derbys Border
    89
    Thats about what I ended up paying. Was extremely disgruntled as it (as stated above) is nothing special.
    If it can't be fixed with a hammer, then it must be an electrical problem
    flat out
    north weald essex
    220
    to keep an eye on it in future.
    get the engine up to temp,
    switch it off,
    spray all the oil marks with brake cleaner.
    watch it magically dry to a nice metal finish.
    then just keep an eye out for any additional oil spills.
