Results 1 to 14 of 14
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    s4 engine on a4 box?
    Will an s4 engine bolt up to a 1.8t quattro box?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,907
    yep, 012 and 01a with have audis "modular" bellhousing, so will fit any of their modern engines.
    TD5 Land Rover Defender build
    May 2008
    perth
    1,197
    Thats interesting. Wish i knew that a couple of weeks ago.
    Aug 2010
    New Zealand
    Something to keep in mind though is that the s4 has a different bolt patten on the crank for the 240mm fly wheel, you will have to get a new 240mm clutch for the s4 flywheel, you cant use the A4 flywheel
    May 2008
    perth
    1,197
    I doubt the a4 clutch could handle the torque anyway.
    jcb
    Sep 2005
    uk
    4,070
    i doubt the A4 box will be pretty to drive with an S4 engine in front of it.
    the torque curve on the turbo V6 will make all the first three gears seem very short I would imagine.
    I preparing myself to be corrected by a detailed comparison of A4 to S4 gear ratios though.....
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    out of interest will an S4 engine fit a 2.4 V6 Tip box?
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    May 2008
    perth
    1,197
    I reckon the 5spd box would be good. 2nd onwards will be fine. I can't see the ratios being a million miles different. Only thing is I would think is that 5th will be shorter than 6th on the s4 box but again probably not by much.
    jcb
    Sep 2005
    uk
    4,070
    significantly different
    S4 1st: 3.500, 2nd: 1.889, 3rd: 1.231, 4th: 0.967, 5th: 0.806, 6th: 0.684
    A4 1st: 3.778, 2nd: 2.176, 3rd: 1.429, 4th: 1.029, 5th: 0.838
    The S4 has longer gears in every gear and a significantly higher top speed potential with a lower ratio sixth.
    you'll be zipping through gears like a drag racer on amphetamines.
    May 2008
    perth
    1,197
    Would be quick getting up to speed then.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,357
    to add to this, the 02a box is not as strong as an 01e.
    You thinking bout that cheap 2.7TT A4?
    May 2008
    perth
    1,197
    Nah but i did see that. Was just thinking about putting a 2.7t in mine but i thought you needed the s4 box as well. Think the engine is gone now anyway. Its a pre facelift engine anyway so i would think i would have needed a facelift s4 loom and ecu to make it go into my car with less hassle.
    Aug 2010
    New Zealand
    Its been done over on zine by someone using the 01A box (I think although it might have been a 2.8 box), The final drive on them is different as well, they dont shear diffs. I cant remember if this was good or bad though.
    "Stick a V8 in it!"
    14,907
    For normal levels of 2.7tt power i dont think its a worthwhile conversion. The stock turbos will do 330ish flat out, and its an absolute pig to work on, and is also a very expensive engine to buy.
    A V8 conversion makes far more sense. Cheaper to buy, similar power and much less to go wrong. Its also lighter.
