Sky InsuranceChris Nott
Results 1 to 35 of 35
    evilscotsman's Avatar
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    well, I got another audi...
    a tdi 1.9 red i, lovin it as i been driving a jap bomber for weeks and you know your back in an audi when you close that door! Subaru doors are tinfoil. Love the B5s again. Gonna pull what bits I can use off the B6 as its officially dead, and then break the rest of the B6 on fleabay or here etc........
    anyway, the tdi, although it drives mint, its got codes..... 00527 intake manifold temp sensor G72, 00553 maf G70, 01265 egr N18, 01262 solenoid boost pressure valve N75, 01269 commencement of injection valve N168. Sheesh!
    Tried clearing with the VAG405 but they come straight back a few seconds later, all sporadic it says, huh! No boost whatsoever, its like the wastegate is open all the time, gets going but no whistle no boost, feels like an na diesel.
    Im thinking its a wiring fault rather than several dud sensors, but anyone know of a common link for these? Or have wiring diagrams I can get in pdf or pics etc?
    Also meant to say, the dieselling sound is very harsh and sharp if you know what i mean, especially in low rev, low gear maneuvering....clatters sharply like a *****. Cant check the fuel pressure yet but I think its in limp mode anyway so need to sort that out first im sure, any help is much appreciated :thumbs:
    cheers
    B4 TDI - old skool project / daily driver...if it ain't broke, it's probably an Audi...
    Aug 2009
    76
    erm i got that solenoid boost fault and i found it to be a dodgy connection on the cable going to the turbo? one of the legs had come out, once i fixed this the boost was back and the car felt like it was alive again! hope this helps
    ... Being British is about driving in a German car to an Irish pub for a Belgian beer, then travelling home, grabbing an Indian curry or a Turkish kebab on the way, to sit on Swedish furniture and watch American shows on a Japanese TV. And the most British thing of all? Suspicion of anything foreign
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    Cheers mate, I think the power fuse is blown that is common to these items but can only find the drivers dash end fusebox, where are the others? cant see any in the engine bay, took the ecu out to check it, the vac connection was full of oil. Think i've cleaned it out by sucking thru a straw and blowing the pipe out, may run it for a minute with the hose off the ecu to pull any crap out of it.
    I think fuse 3 is connected to the sensors mentioned above (from a post elsewhere) but cannot find any other fuse box....grrrrr.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,311
    Theres only one fusebox on a B5.
    One of the 1.8T guys had a similar fault with a whole pile of sensors having dropped out, and it was a wire having chafed thru and shorted out the feed to them.
    TD5 Land Rover Defender build
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    mmmm sounds likely, think they did it when they put a replacement engine in, will have to have a good look around the engine bay, may try patching a feed into the maf wiring and see if they return, dont suppose you would know where it likely rubs or is that a stupid question lol?
    "Stick a V8 in it!"
    15,311
    never worked on a tdi, so i dont really know wheres most likely, just need to follow all the loom and look for damage.
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    had a test round after work, none of the mentioned sensors have any supply voltage at all, well maybe 0.09v and resistance to earth starts at 120R then rises as the meter scale is increased, which points to an internal fault in the ecu, I think thats where the power comes from.
    Gonna patch a 12v feed into the wire via a 21w bulb, so if its shorting inside the current will be limited by the lamp, if nothing bad happens, may leave a feed onto it to get it to work right until I get to the bottom of it, the bloody engine sounds like a transit Di, sharp and clattery lol its doin me head in, guessing pre-injection is normally used and isnt working now....start of injection valve 108? same circuit I reckon...
    doh!
    Aug 2009
    76
    Could you not put a inline fuel filter along the vac pipe? that should stop the backflow, if im not mistaken theres a couple of big fuses inside the ECU box...i think..
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    I may be interested in a couple of bits from the b6. Im in perth too so could collect.
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    hey Ian, no problem. Have to tow it back from the garage and im gonna use anything that will fit the b5 but what ya after?
    jonnyf, dunno mate about fuel filter, not bad idea might stop oil going into the map right enough but I reckon this ones had it. your right there are 2 big ass 40A fuses in there but this cant be a high current job, the wires to the sensors are too small.
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    SOLVED!
    was a small 15A fuse down in the bowels of the ecu compartment, engine control supply S102, nearest you on the rhs when you lift the ecu out. Never saw it before cos I slid the ecu out the end, didnt remove the lid completely as the rear bolt is a pig but decided to get at it properly today to have a good butcher's.
    This fuse caused no boost and 6 sensor fails, cant wait to drive it with BOOOOOOOST!!!
    running sweet as a nut, only one real code, IAT sensor (sporadic), but thats for another day
    Yee Haaaaaaa!
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    glad you got it sorted got any pics on the B5?
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    Aug 2009
    76
    yeah i seem to remember there being a few small current ones in there aswell! glad you fixed it! yeah nightmare to get that last bolt out innit, i actually lost one and never found it to this day....haha
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    Here is the only one I have just yet, will get it washed and put better ones up. First thing on it will be the 17's off the B6 Sport I have, and the steering wheel lol....jonnyf was the first one to suggest the ecu box, but like me only noticed the big fuses, little ones are hidden unless you take the top right off and the ecu out.
    Wonder if the B6 suspension would fit on the B5? Probly not, anyone know what will fit between them?
    Also have this mad-arsed maniac - 301bhp, 2.0 16v Quad-Cam Twin Turbo (ballbearing IHI VF's) - getting MOT'd at the mo..too dear to run to work every day but jeesus H christ it is crazy quick. 3" stainless Hayward & Scott exhaust from the turbos back, 2nd turbo is decatted. Running 1.2 bar of boost at present. (standard boost)
    This is my B6, I'm breaking it now (engine fooked - sludge) - 1.8T Sport 163.
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    the b6 looks nice i remember this while back, IIRC the b6 has bigger discs
    what year is the b5? hope you got a good deal
    Aug 2009
    76
    those ones on the b6 are the ones that are on mine! one of the best ones imo!
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    like your sig jonny
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    yep, i still like the sport wheels best myself, ta jonny
    Ras, yeah the Sport has even bigger discs than the standard B6 ones, but I would like to find out what exactly does fit a B5, off the B6 cos I will use whatever I can and sell the rest on here or fleabay. Body, interior and gearbox are mint on the silver one, same with tinted glass, electric heated mirrors (silver lol) and all lights and ancillaries. It also has the lower stiffer red suspension. If it was easier, I would transplant the engine and box into the B6 but not a straightforward job and the tractor is my daily now.
    The Legacy GT is enough fun for anyone, the look on the wee chavs faces when they roar up to your bumper at 70, revving the nuts of the corsa/106/sao/etc...you sink the pedal in 5th, both turbos hit full boost, the boxer emits a demonic growl, in 3 seconds you will touching 120, and 3 seconds later hitting 160....the chavs are no longer visible, you're too far away. It clears 100 in 3rd at 5k, redline is 7k. :lol:
    The bass from the 3" stainless H&S exhaust & WRX decat pipe vibrates windows in our street and sets other car's alarms off..
    Here is a sound clip of an identical one on another scooby forum members car: (I havent got round to vidding my bigzorst noise but mines exactly the same) - Turn The Bass Up!!!!! You can hear the turbos spinning down....mmmm
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    Quote Originally Posted by rasA4 View Post
    The B5 is a 1995, cost me sweetie money, honestly. Cos of the faults and the CEL, no boost etc, the guy sold it just above scrap price so I did rather well, but then im not afraid of an electrical fault as its what I do for a living, others werent keen on buying it because of the obvious I suspect. Its still got 6 months tax and the lad was very honest about the car, a thoroughly nice bloke. (cheers Mike )
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    how does it compare to the b6 i would have thought the b6 would be a lot newer and tighter feel?
    dont think the b6 steering wheel will fit your b5
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    B6....The Sport suspension is too hard, the steering vague and the brakes wooden, its a barge lol. Kinda fast, but over-stressed wi the 1.8T motor I think. Needs 200 bhp plus to be really sparkling, with 163 bhp and being such a lard-arse its not that great really. Looks nice, interior very very good but then so is the B5's interior. I think the B5 drives better honestly, I've had 2 and both were the same. The B6 is too heavy to be fun but nice to look at on the driveway. Still has crappy rubber coating on all the buttons that still peels off.....they need to shoot the twat that came up with that idea lol.
    "Stick a V8 in it!"
    15,311
    Quite a lot of the front end of the b6 will fit teh B5. The alloy uprights, and all the arms etc will fit, as will the suspension itself, although the spring rates might be funny.
    Rear end is totally different though.
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    bugger! ah well, guess i will have to sell the Sport suspension then lol
    Anyone for bits? 52 plate B6 Sport, Silver, charcoal nappa interior (50k car, like new no wear!) everything there except the top end of the engine or the turbo....
    The tractor needs slammed, its like a 4x4 jeep
    jcb
    Sep 2005
    uk
    4,077
    pics of the interior and dibs if it is nice!!
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    will do mate, its lying at a garage just now but got to get it brought home for stripping down soon.
    Its a dark charcoal silky nappa that looks like leather kinda from outside, till you feel it and realise its cloth, but it is like new, my kids are adults and the car only did 50k before the engine went from sludge. sickner but what can you do, they want both kidneys for the right code replacement engine so feck it lol. Its sat for a year so the interior will need valeted no doubt, I'll see what I can do.
    It is the standard Sport interior so if you like it, thats no prob, its yours provis etc etc. Just chuck me a pm to remind me you said first lol.
    The trims are polished charcoal, as it was fishscale aluminium but I swapped with a lad on here for the charcoal when the car died. Its nice tho, looks better I think.
    "Stick a V8 in it!"
    15,311
    Why bother trying to find the right engine? Just get any 1.8T and nail it in?
  28. #27
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,503
    ^^ thats what i would do,lol
    Use the sensors/IM / ex mani and sump pan from the 163 and put an AEB or similar in it. The turbo is the same.
    What engine code was it? I wonder if its 06a or 058 style engine...
    Oh and if you do break her, let me know how much you want for the wiper linkage, siezed or not
  29. #28
    May 2008
    perth
    1,197
    Wher in fife are you?
  30. #29
    "Stick a V8 in it!"
    15,311
    it'll be an 06a, but that shouldnt really matter i dont think? Unless the mounts are different?
    If it does, just make sure the replacement is an 06a block
  31. #30
    Apr 2004
    12,503
    yeah i think the mounts are different
  32. #31
    "Stick a V8 in it!"
    15,311
    d;oh
    Wonder if the 06x block from the A3/Golf will fit?
  33. #32
    jcb
    Sep 2005
    uk
    4,077
    just pull the mounts of your existing 06a and bang em on the 058 block you replace it with.
    there is no difference externally to the mounting holes AFAIK
  34. #33
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    I am near Cupar in Fife.
    The engine centre told me and the garage that the gearbox in mine was only used 01< so only 2 engine codes will fit, (BFB & AJL) - mines a BFB if I remember right, been a year and a half since it broke. Its also one of only 2 longitudinal engines which means a lot of things are different from the transverse units and they are not easily interchangeable im told. (quantum performance engineering)
  35. #34
    "Stick a V8 in it!"
    15,311
    The gearboxes are all the same afaik. Yes the particular code might only be used on early cars, but they didnt change the bellhousing or anything. Any 1.8T (and infact any V6/V8 too) will bolt up to your gearbox.
    AJL is a pre-B6 engine, fitted to 180hp B5 TQS's
    ALL B5/B6/B7's are longitudinal, so basically the garage are talking ****e. Sounds to me like they're not actually mechanics, more like one of the many modern part fitters that seem to call themselves mechanics. If the part numbers dont match up then they have a brain fart and run away crying for mum.
    The main differences with the transverse engines are the manifolds, and the flywheel, both of which are easily transferred from your current engine, but given there are millions of longitudinal engines out there anyway it should be hard to find one that will slot streight in.
  36. #35
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    ah ok cheers mate, being a sparky myself I sometimes take it as read when a mechanic says stuff, will have to stop that lol cos I know what you mean, theres a difference between an automotive engineer and a fitter (no disrespect to fitters)
    Most local garages I took it to when it broke were afraid to even take it on at the time, thats why I gave up, wasnt going to get humped by an audi dealer but it was looking likely.
