Chris NottAH Fabrications
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,875
    dump valve on 1999 a4 1.8TQS (180bhp)
    any1 got any pics off there dump valve on there car so i can see how to mount mine when i purchase it in next few weeks ??
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    jcb
    Sep 2005
    uk
    4,070
    why do you want a dump valve?
    the car is set up to recirc the vented charge back into the TIP. if you dump it you may through some codes, you will certainly end up running a bit rich and you could end up with worse performance.
    much better getting a decent recirc valve.
    If it the noise you are after just get a sheilded cone instead of the airbox
    Aug 2010
    2,875
    How do I go about the sensor on top of air box when fitting a cone ?? Was looking at getting the splitter from forge ?? Any easy to mount ??
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,922
    That's just the ignition amplifier. I just zip tied mine out of harms way. Never had a problem with it.
    Life begins at 140mph
    www.passionford.com
    Aug 2010
    2,875
    Cheers will do !!
